question about charging
This may sound stupid but would it be ok to charge a battery through a 3inch peice of 0 gauge. heres why i ask because i have tsnuami battery terminals and my clamps arent big enough to go around it and the only way to take the battery terminal off to get to the post is take the whole battery out which is a bitch considering its too big for where its at and i was thinking of just putting a little peice of 0 gauge in one of the terminals far enough out so i could get the clamp on it. would that be an issue or no
08 Ford F150
That's fine. Just make sure there is no change the positive piece can touch anything else
x2. this cant be stressed enough. if that 0 gauge touches ANYTHING metal (even a single tiny strand) aside from the positive terminal on the battery and the + clamp on the charger, sparks WILL fly and electronics may get damaged/fubar'd.
Pics would be helpful, but I would personally go with bigger clamps to solve the issue rather than having a bare positive terminal dangling 3 inches from the battery.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
If you do this, wrap a shop cloth or rag around the whole (+) assembly and clamp so your not touching anything.
A cloth would be better than nothing but touch that cloth with a grounded wrench and see what happens.
CURRENT SYSTEM:
  • Alternator:
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
    • Mids RE XXX 6.5c
Build Log
  • Who's Online   0 Members, 0 Anonymous, 2460 Guests (See full list)
