I gotta get on my computer after work. Idk if you can do it from mobile. As of now i have moved up to a Skar 1500.1 and i put my Kicker cvr 15 to replace the missing E15 so i can still have music.
Pioneer DEH-9400
Kicker door Speakers
Rockford R400.4
Skar 1500.1
2 DC lvl 2 15s
Just cause you used a dd-1 doesn't mean it's the end of clipping
Using the -10db track increases the possibility of clipping cause all songs are at different volumes
So if a dd-1 doesnt stop clipping and distortion why is it highly sold and used? Is it a "kinda of sorta of distortion dectector?" Smh
93' Exploder
Deck:Pioneer 6400-bt
Front Stage: Crescendo PWX 8"s and Skar Audio VX1-ST per door
Amps: Sundown Audio SAZ-3500 v1 @.375 ohm daily, CT Sounds 125.2
Subwoofer: Two PSI Platform 2 18"s,Fully Loaded D1.5's
Enclosure: B Pillar Fourth Order, 3:1 ratio tuned at 46 (Designed by Low Hertz Box Designs)
Wire: All Sky High Car Audio Cable!
Alternator: Singer 250 amp Hairpin
Batteries: XS Power D975
Team Audio Connections
I'm guessing you don't know how the dd1 works. It doesn't matter if you use the dd1, if you play the wrong type of music you can still be clipping
Alpine 9884
RF T2 comp set up front
The Epicenter
2x RF T10001bd
2x Sundown sa-15 t-line
Big 3
Smd DD-1
I have a dd-1 and use it and recommend it to my friends or anybody I can
After your done setting your gains you still have to keep an eye on your system this is were the ear comes in if your within your setting and you can hear/see distortion/bottoming out back it off a lil bit
Dd-1 and some common sense=FTW
there are a few things that screw with you after the tune from a dd-1 like moving anything up on the EQ after tuning or playing already clipped music or dropping voltage. sundown rates the E at 400 watts and they know it takes 700 clean to kill it so when they see a thermal failure they know its user error.
REP
I know for a fact a e15 cant handle 700 watts smelled it with my own nose.
+1
93' Exploder
Im running a e-12 on a mtx 81000d at 2ohms for one year now set with a dd-1 and it sounds great never smelly.
I dont know why everyone has been bashing the DD1. If you watch the videos that Steve and Tony have made you will realize that its is essentially an O-Scope with a dummy light. It shows when you have a clipped or distorted signal when used properly, 99 percent of the dd1 problems are user error. Even if you used a 0db track and used an o-scope, depending on what track you are listening to and how you set up the headunit/eq will still be able to clip at certain frequencies and burn up your drivers.
2004 Dodge Ram
Head unit- Alpine iDA-x305s
Sound processor- Clarion eqs746
Mids/Highs amp- Alpine MRV-F345
Sub Amp- Alpine MRD-M1005
Dash Speakers- (3) Dayton Audio rs75
Front Door- Skar SPX65c
Rear fill- Skar SPX tweters and Dayton ND140 midbass
Sub- Fi Audio SSD 15 high QTS
SHCA power/ground cables and Stinger interconnect
XS power D6500 under the hood and D680 in the amp rack
Big 3+ with SHCA
http://www.stevemeadedesigns.com/board/topic/161174-dodge-ram-quad-cab-fi-ssd15-skar-audio-alpine-shca/?p=2326251
  • Who's Online   0 Members, 0 Anonymous, 1533 Guests (See full list)
