Rmichael91 Posted February 6, 2013 Report Posted February 6, 2013 A quick search on google, multiple sources, shows your anywhere from a 60amp alt (odd in my opinion), to a 110amp stock alternator. Leaning towards the higher, I would suggest a high output. Mechman and Singer both build a few units. You don't necessarily need the XS batteries, you could use the REMY Dekas and be fine. But do the big 3 in 1/0 and a run from the front battery to rear battery.
Ratski Posted February 6, 2013 Author Report Posted February 6, 2013 A quick search on google, multiple sources, shows your anywhere from a 60amp alt (odd in my opinion), to a 110amp stock alternator. Leaning towards the higher, I would suggest a high output. Mechman and Singer both build a few units. You don't necessarily need the XS batteries, you could use the REMY Dekas and be fine. But do the big 3 in 1/0 and a run from the front battery to rear battery im still kinda new but i havent read thru the the big three yet. but my plan was to run 1/0 from the alt to the main battery and 1/0 to the rear battery, 1/0 grounds as well so you have a good return. and then put in a h.o. alt
Ratski Posted February 6, 2013 Author Report Posted February 6, 2013 just read through the big three and thats a simple setup and can be done at the same time when installing the new battery
ChevyBoy95 Posted February 6, 2013 Report Posted February 6, 2013 173,374 AAA batteries. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
Rmichael91 Posted February 6, 2013 Report Posted February 6, 2013 just read through the big three and thats a simple setup and can be done at the same time when installing the new battery And then when your alternator comes, you only pull 3 bolts, plus a nut (typically), swap it out, then replace the nut and 3 bolts. Toyotas may be a different set up. I'm more accustomed to Hondas, Ford, and GM.
Jskiles Posted February 6, 2013 Report Posted February 6, 2013 173,374 AAA batteries.That would be 1 hell of a shockEdit- if you series aid the AAA batteries. 260K volts 2010 Kia Forte Koup (Slow Build) 2 Sundown SCV-3000D 2 DC XL M1 with PSI reconesFocal R-165s2 on Orion 4800-HPKenwood KDC-X798Knukonceptz OFC 1/0Audiotechnix,Fatmat and Q-mat Deadener XS power D3400 up front 3 D3100s power in trunkStock 110 amp alt 2013 Scion TC 2 Dc lvl 3s with xl coils on Soundqubed 2200 Sundown components AA 50.2 for components Pioneer FH-X700BT Knukonceptz OFC 1/0 Fatmat and Q-mat Deadener XS Power D3100 up front D925 in back Mechman 240 alt http://www.stevemeadedesigns.com/board/topic/189911-2013-scion-tc-build/ <Scion TC Build http://www.stevemeadedesigns.com/board/topic/174094-jskiles-forte-koup/ <Slow Kia Forte Buildhttp://www.stevemead...ockUserAgent__1 < Old build 2005 Equinox
def loudness Posted February 7, 2013 Report Posted February 7, 2013 Ratski....just go with a GM CS144 (cross ears)hi-output alternator...with little modifications to it and a longer serpentine belt. Do a google search....a lot of Toyota trucks and 4Runner has this upgrade.
Ratski Posted February 8, 2013 Author Report Posted February 8, 2013 yea that 144 modd is pretty rad.. now if i got with one dekka in the back and just my reg batt in the front and an ho alt would that be adequate?
Ratski Posted February 8, 2013 Author Report Posted February 8, 2013 Ordered up my dekka battery today should be here soon. Try and run the Delia out back and keep my regular in the front and see how she does if not so well ill just add another Dekka to replac the front batt. Now just gonna decide on an alt and be ready to wire her up
