I need to do some more reading on this. I am just sorta hesitant to put any in in fear of messing up my engine. 12 years old and 138k, never seafoamed
'01 Dodge Stratass Sealed Trunk Build Log
2008 Honda Fit Sport Build Log
On 10/3/2013 at 10:00 AM, ROLEXrifleman said:
Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
Yes I send my oil out every 4-6k for analysis to set up a trend. No point in changing perfectly good oil at 6k miles if it is in damn near the same shape it was at 0.
to who? i have never heard of anyone doing that.
http://www.oaitesting.com/
http://www.testoil.com/
Useful as well to see if you have any metal in the oil.
  • pa-pa-platypus
  • sorry not everybody has a companies nuts so far down their throat they catch every drop ball sweat when it falls
Why not , the Idea of sea foam is to soften carbon in the fuel tract and even get the injectors spaying in a uniform pattern. I have had great luck w chevron w techron. Injector treatment or total fuel sys cleaner
Just did it to my 2003 with 130k miles on it. picked it up at Napa for 7$ and man my car runs a little smoother and all my friends say my exhausts sounds better (this was said before I told them about the seafoam so no placebo). However I made the mistake of pointing my exhaust towards my back yard. but the stuff works man. Since Saturday I've had to help people run it through 4 other cars after they saw my results.
when you put seafoam in the oil either change it after 10 min at idle or you can drive 100 miles then change the oil.I put that shit in the gas tank, break booster hose, and in the oil.
02 dodge ram 1500 reg cab 3rd gen
2 sundown sd-2 d4
soundstream rub1.2500 amp
all sky high car audio-fuse,fuse holder,wire,ring lugs and rca
flex tech
box design by Joe X
supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch
04 5.7l hemi motor swap and made it an slt eletric everthing
youtube channel-http://www.youtube.c...43?feature=mhee
http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
