wich one is the best to choice?
vw passat
Neither have enough port. Areo ports min of 9 and slot a min of 12.
your port area per foot should be higher. the configuration you're using is for an areo port. that numbe should be at least 9, your at 8.07 and 7.18. . What subs are you building the box for
2 4" or 1 6" will work if you use aero ports.
Only issue I see - when I calculate 2 4" ports in 3.5 cuft net volume, I get a length of 14.8", not 13.6 for 33 Hz tuning. And with aeros you have to add 1" to account for the end factor, so you will have to bend them.
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
  • Who's Online   0 Members, 0 Anonymous, 679 Guests (See full list)
