Question on Bi-amping components
hhowell1990
I just got a DEH-80 PRS in my truck and wanted to run the RCAs as hi/mid/low instead of front/rear/sub. My plan is to run a set of RF T2 5 1/4 components in the doors, and rear of the cab and T2 6 1/2s in the kicks and behind the back seat. I want to bi-amp my setup and wanted to know if the 6 1/2s are rated at 100w RMS and the 5 1/4s are rated at 75w RMS if i can run that to each driver or if that's total RMS for the chanel?
You would need 2 4 channel amps to bi-amp and split the signals from the HU or Install a line driver off the high level output from HU to have enough Channels to run that many amps. You do know what Bi-amping means right? and why put the smaller speaker up front?
It's the total power, so 100w (or 75) for the tweeter and midbass together.
Sorry it took me a while to get back to you, didn't realize that i had turned off e-mail notifications. That's kinda what i figured, and i should probably run the tweeters with less power than the midrange otherwise they'd just overpower everything. right?
  • Who's Online   0 Members, 0 Anonymous, 1085 Guests (See full list)
