purplesyrup Posted February 13, 2013 Author Report Posted February 13, 2013 Oh, and don't listen to what he's saying about the alts, he clearly doesn't know what he's talking about. maybe I just spoke with a senile old man for 30 minutes? lol
purplesyrup Posted February 13, 2013 Author Report Posted February 13, 2013 DC power list a 250 or 270 for your car.....Did you look at them https://www.dcpowerinc.com/high-output-alternators.html?make=Ford&model=Fusion&year=2007 Well hell yea, after speaking to this guy I was like wtf, thanks for the help fellas 270 it is
purplesyrup Posted February 13, 2013 Author Report Posted February 13, 2013 Ok, so the DC power 270amp idles at 200amps, anyone know where these peak? I owuld like to see full output at 2,000 rpm
Lbox88 Posted February 13, 2013 Report Posted February 13, 2013 http://blog.dcpowerinc.com/2011/09/09/how-pcm-controlled-alternators-work/ UBL | Build Log
purplesyrup Posted February 13, 2013 Author Report Posted February 13, 2013 I sent in a quote through mechman also, that guy must have been on crack
Gingeriffik Posted February 13, 2013 Report Posted February 13, 2013 Click the performance tab on the page at DC, it has a breakdown of RPM performance. <>< Collosians 2:13-14, Philippians 4:13, 1 John 4:7-10 2 - JBL W15Gti 2 - JBL BP1200.1 Knu 1/0 Wiring Kenwood KIV-BT901 Kenwood/Garmin Nav.
Ninja_v1.0 Posted February 13, 2013 Report Posted February 13, 2013 I know at least mechman or DC does...... because teh ninja has one in his fusion. Yea but ninja was telling me that the one he got did next to nothing, that the PCM control doesn't allow for greater output alts, which makes me think he got sold potentially a stock one and that may have been where ever he got it froms excuse of why its not performing greater NO NO NO.. I have a dc power 270xp and that alt is a beast for the car. I have put that alt through hell and it keeps on producing like I expected. What I said was that with our cars you will have a hot charge of about 14.4-14.6 and once the alt gets hot you will be around 13.4-13.6 hot charging. Good thing about the xp is it does GREAT output at idle so you should still see over 200amps hot at idle. You can actually get a 370xp for the car but you will have shit at idle as with all 350+alts. Make sure you have the v6 because this alt is a BEAST in itself. If you have any other questions let me know. If you order from dc power make sure they send you the adapters. When your at the top everyone is coming for you, friends, family, haters and even those who don't know you.. my advice.. KILL EM ALL
Ninja_v1.0 Posted February 13, 2013 Report Posted February 13, 2013 Singer would have to use your case that your current alt is in right now leaving you without an alt Mechman last time i checked did not make a stronger alt than the Dc 270xp for our cars When your at the top everyone is coming for you, friends, family, haters and even those who don't know you.. my advice.. KILL EM ALL
purplesyrup Posted February 13, 2013 Author Report Posted February 13, 2013 I know at least mechman or DC does...... because teh ninja has one in his fusion. Yea but ninja was telling me that the one he got did next to nothing, that the PCM control doesn't allow for greater output alts, which makes me think he got sold potentially a stock one and that may have been where ever he got it froms excuse of why its not performing greater NO NO NO.. I have a dc power 270xp and that alt is a beast for the car. I have put that alt through hell and it keeps on producing like I expected. What I said was that with our cars you will have a hot charge of about 14.4-14.6 and once the alt gets hot you will be around 13.4-13.6 hot charging. Good thing about the xp is it does GREAT output at idle so you should still see over 200amps hot at idle. You can actually get a 370xp for the car but you will have shit at idle as with all 350+alts. Make sure you have the v6 because this alt is a BEAST in itself. If you have any other questions let me know. If you order from dc power make sure they send you the adapters. Ok cool, my misunderstanding there, I have the v6
Swordlordboy1234 Posted February 13, 2013 Report Posted February 13, 2013 If budget is any factor at all check Tenney. Robin from BassHeadsEnt runs them, a 370 and a 350 in his Tahoe. Reel fish on SMD with the S10 runs one. Will with rolling thunder using skar runs a Tenney. I run a Tenney and I get all the power I need for my sk2500.1 and a t600-4 full tilt. I also have zero belt squeal which is something I've herd about some cases with those other companies (not mechman thou) ... If I get flamed for supporting Tenney. Hey.... Pay your extra $$ then. I recently moved from Fort Lauderdale Florida to San Marcos Texas.... And pounded my system full tilt the whole way (25 freaking hours of driving I was a bit tired of bass almost)..... Never once dropped into the 12's and never once had an issue with overheating........ AND the last 100 miles I was doing over 4k rpms and 95mph and it still holds strong hot or cold in any weather. My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect?
