Brian Needham Posted February 14, 2013 Report Posted February 14, 2013 embarrassed to ask but gotta learn some way... 3 way components up front (6ch amp) rear door speakers (4 ch amp, only using 2 ch) 1 sub (mono amp) can I run all that through the 3sixty.3??? if not is there a processor that can? thanks
n8ball2013 Posted February 14, 2013 Report Posted February 14, 2013 you can run everything through that. It might be able to make you coffee too. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
RCP Audio Posted February 14, 2013 Report Posted February 14, 2013 should be able to although ive never used one PSN: Rcp_soundz Good rule of thump is go by what fuse size is being used in these amps. The higher the more amperage it pulls, this is what I look at. I'll stick a 300 amp fuse in a potato and sell it to you for $2k. 1991 Mazda 323VERY small build thread here: http://www.stevemead...23-small-build/
Kyblack76 Posted February 14, 2013 Report Posted February 14, 2013 ALL active???? SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
OrionStang Posted February 14, 2013 Report Posted February 14, 2013 360.3 gives you 8 channels. 6 channels for your 3-way front, 1 channel for subs, leaves you one channel if you want to use it for your rear doors, but it wont be stereo. SMD Super Seller My Feedback Thread
Brian Needham Posted February 14, 2013 Author Report Posted February 14, 2013 ok cool...........here is where I get confused........what I have listed is 9 channels, with the 3sixty3 only having 8 output channels. I was thinking of using the amp crossovers (zed amps) if it makes a difference.
Kyblack76 Posted February 14, 2013 Report Posted February 14, 2013 I figured.... SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Brian Needham Posted February 14, 2013 Author Report Posted February 14, 2013 I figured.... figured what? I know it may be a stupid question to someone of your experience.....how would you do it?
Kyblack76 Posted February 14, 2013 Report Posted February 14, 2013 Not what i ment..... Sorry... SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
