2004 ford mustang GT
front to back-everything audio is needed. i currently have just stock audio. all of my money has gone into the engine, suspension, etc...
i am just fishing for some ideas. my goal is to get the most i can and keep it at $3000
crazy=good
Trunk or backseat/wall?
06 Police TahoeHU- Pioneer 80prsAmp- Crossfire 8kSub- 4 15" Crossfire xs v2sWire- 1/0 Knu/AudiotechnixAlt- 3 Mechman SMD 340sBatts- 6 XS Power 3100s, 2400
Welcome buddy. Are you looking for a trunk build or are you trying to get as loud as possible and don't mind taking out your back seat for a b-pillar wall?
edit: ninja'd.... damnit i'm slow
Audio Build
Ride: 2002 Chevy Blazer 4 door
Head Unit: Pioneer deh-80prs
Subs: 4 DC Level 3 15's in a 4th order wall designed by Trent Choate and Jeff Smith
Subs Amp: AQ 3500.1 at wired at .5 (soon to be 2)
Mids/Highs Amp: Skar 85.4
Mids/Highs: Skar components
Electrical: Mechman 270 amp alt, 2 runs of Knu 0 gauge, XS Power d3400, 2 Deka Group 9a31
Build log : http://www.stevemeadedesigns.com/board/topic/167658-indianabasshead-blazer-dc-audio-4th-order-wall-build/
Perfomance Build
2003 Nissan 350z
Greddy Twin Turbo, 3" Test pipes with Borla high-flow cats, Crawford Performance Plenum, Greddy E-manage Ultimate ECU
Exedy Racing Clutch, Built Motor by Racing Innovations
Greddy Over-fender aero kit (1 of 20 ever made), 19" Racing Hart r5 pro wheels
466rwhp
Bike
2008 Midnight Blue Kawasaki ZX-14
Stretched 8" and lowered, Brocks Sidewinder exhaust, Power Commander 5
Welcome David, do you want so loud as possible, or more a sound quality loud or a sound quality system?
thanks for the welcome, "sound quality loud"; i want to be able to understand what is being played, but still knock my fillings loose.
@420c
-if need be i will pull the seatdepends if i can get what i'm after and still keep it in the trunk
@420c
By your trunk i guess you 2 AA Havoc´s loud very musicaly SQL sub, a 2.5 - 3.5 K monoamp from DC audio, Sundown, Skar, 4 channel amp 4 x 125 watt @ 4 Ohm.
3 set´s of comp´s like this http://www.sonicelectronix.com/item_33492_Kenwood-eXcelon-KFC-X1730P.html2 in the door´s on 2 Ohm, 1 set in the rear on 4 Ohm.
a H/O alt 250 and up from Mechman/DC Power/Singer, get a quote of them for your car, and a second in the trunk, best is XS-Power. If you havent a AGM under the hood,
switch them out for a AGM and sounddeadner.
"in the abundance of water, the fool is thirsty" Bob Marley
2 tantric hdd or aq hdc3 10's on a dc 5.0k
Used to have a loud truck
@420c
thanks
Headunit : Hands down the best for the money - http://www.sonicelectronix.com/item_43523_Pioneer-DEH-80PRS.html?SearchClickout%5Bquery_id%5D=16677737&SearchClickout%5BIgnore%5D=1
Component speakers : 3 sets of these... also very nice for the money - http://www.amazon.com/VXI65-Skar-Audio-Component-Loudspeaker/dp/B0089F3NE8
Subwoofers : 2 of these 12" - http://obsidiancaraudio.com/index.php?id=6
Sub amp : Very nice amplifier for the money - http://www.soundqubed.com/Q1-2200D_p_31.html
mids/highs amp : http://www.soundqubed.com/Q4-120_p_150.html
under hood battery : http://www.amazon.com/XS-D4700-Battery-Terminal-Hardware/dp/B00B7WIKJS
rear battery: http://www.amazon.com/XS-D3100-XS-Power-D3100/dp/B001GMTIO0/ref=sr_1_1?s=electronics&ie=UTF8&qid=1361025446&sr=1-1&keywords=xs+power+d3100
Alternator : contact singer, dc power, or mechman for quote
I do run a lot of this equipment... I am not promoting the companies in any way but IMO, these are honestly some of the absolute best performing equipment for the money. With this setup, your car would sound very good. And with a correctly built box, these subs will get pretty loud in your car.. I think you will be pleased.
All of this equipment listed puts you at $2350. That leaves you enough to purchase wiring and the alternator. Plus you will have a little bit of cost for a subwoofer box, but as long as you can build it yourself, it won't be expensive.
Audio Build
Perfomance Build
2003 Nissan 350z
466rwhp
Bike
  • Who's Online   0 Members, 0 Anonymous, 470 Guests (See full list)
