bdog Posted February 20, 2013 Report Share Posted February 20, 2013 pretty sure clipping while strapped with two high end amps is a bad thing, gonna cost you more in the long run. lead acid batteries might be hurting your friend not the best for voltage drop. check all your grounds for resistance find a new spot if you need to may need more pos/neg runs to amps. check all your voice coils separately make sure you havent toasted one already get the batts checked separately one bad one could do you in. get a cheap volt ohm meter from homedpot 10-15 bux good luck nice set up. I dont know why it only seems to do it when ur fully charge or what not but im guessing that with you not running two high output alts that you drop is huge prob 9-10v REP Link to comment Share on other sites More sharing options...
AmmoJammo Posted February 20, 2013 Author Report Share Posted February 20, 2013 I couldn't find a manual for the Z1.. the M4 appears to have overload protection, which I assume is a low impedance type of protection.... and I'm wondering if that has something to do with it. Link to comment Share on other sites More sharing options...
__d_a_v_i_d__ Posted February 20, 2013 Report Share Posted February 20, 2013 1 3100 for 2 m4s at 0.5 ? Chevy Impala Shocker Sigs / TC Sounds 12s Sundown NS-1 | SAX 100.4 Sundown Neos | Dayton Audio Neos ETCCC ETCCC ETCCC My YouTube ---- Subcribe!! Link to comment Share on other sites More sharing options...
bdog Posted February 20, 2013 Report Share Posted February 20, 2013 1 3100 for 2 m4s at 0.5 ? thats what he says.. YOU NEED MORE POWER!!!!! 4 3100's and atleast one 300 amp alt!!!! and get a dam volt meter!!!! REP Link to comment Share on other sites More sharing options...
__d_a_v_i_d__ Posted February 20, 2013 Report Share Posted February 20, 2013 We found the problem, idk why we have 2 pages for this . User fail ! Major fail . Be glad amps go on protect as not poooooof Chevy Impala Shocker Sigs / TC Sounds 12s Sundown NS-1 | SAX 100.4 Sundown Neos | Dayton Audio Neos ETCCC ETCCC ETCCC My YouTube ---- Subcribe!! Link to comment Share on other sites More sharing options...
AA98hoe Posted February 20, 2013 Report Share Posted February 20, 2013 Pretty sure it's a input voltage issue .. An protection circuit issue.. I had same problem until m amp guy modded my protection circuit .. Anything under 1 ohm dd amps like to protect full tilt .. Wire it up I bet it goes away .. Turn gain down also an add more batterys TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5. Link to comment Share on other sites More sharing options...
n8ball2013 Posted February 20, 2013 Report Share Posted February 20, 2013 can try rolling into it too. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger. Link to comment Share on other sites More sharing options...
C-Fizzy Posted February 20, 2013 Report Share Posted February 20, 2013 No it's a d3100 for 2 z1's strapped at 1 ohm. Are you kidding me. under construction I hate People with crappy primered cars rolling on hubcaps that are louder then me. u hate c-fizzy? Link to comment Share on other sites More sharing options...
n8ball2013 Posted February 20, 2013 Report Share Posted February 20, 2013 he was todl it wasnt enough. he didnt listen. Im just giving him more options to smoke an amp. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger. Link to comment Share on other sites More sharing options...
C-Fizzy Posted February 20, 2013 Report Share Posted February 20, 2013 I'm just surprised that he's running those amps on that kind of electrical. Fuck you have balls. under construction I hate People with crappy primered cars rolling on hubcaps that are louder then me. u hate c-fizzy? Link to comment Share on other sites More sharing options...
