Digital Designs M4 and Z1 protection "issues"
AmmoJammo
pretty sure clipping while strapped with two high end amps is a bad thing, gonna cost you more in the long run. lead acid batteries might be hurting your friend not the best for voltage drop. check all your grounds for resistance find a new spot if you need to may need more pos/neg runs to amps. check all your voice coils separately make sure you havent toasted one already get the batts checked separately one bad one could do you in. get a cheap volt ohm meter from homedpot 10-15 bux good luck
nice set up. I dont know why it only seems to do it when ur fully charge or what not but im guessing that with you not running two high output alts that you drop is huge prob 9-10v
REP
1 3100 for 2 m4s at 0.5 ?
thats what he says..
YOU NEED MORE POWER!!!!! 4 3100's and atleast one 300 amp alt!!!! and get a dam volt meter!!!!
REP
Pretty sure it's a input voltage issue .. An protection circuit issue.. I had same problem until m amp guy modded my protection circuit .. Anything under 1 ohm dd amps like to protect full tilt .. Wire it up I bet it goes away .. Turn gain down also an add more batterys
TEAM DC AUDIO
VEHICLE:98 chevy tahoe 2wd 3-4 drop
HEADUNIT:alpine 9886
PREAMP:arcaudio
FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door
KICKPANELS:jl audio 5 1/4
REAR DOORS: dd components 6 1/2s
HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors
SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV
SUB AMP: 2-dc7.5s
ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
can try rolling into it too.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
he was todl it wasnt enough. he didnt listen. Im just giving him more options to smoke an amp.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
  • Who's Online   0 Members, 0 Anonymous, 1817 Guests (See full list)
