CHINO11550 Posted March 4, 2013 Report Posted March 4, 2013 So why is it that more batteries/more charge results in the amps going in to protect more? that's what the question has been the whole time, and no one has been able to answer it.... amusing responses, but very uninformative. The amps dont like to be strapped that low !!!!!!!! unstrap.unstrap.unstrap.unstrap H/U Pioneer deh80prs w/ HRT iStreamer Ipod DACFront stage is active, 4 Morel Elate 6.5" & 8 CDT DRT26 tweetsamp running 4mids, Mosconi Audio 300.2amp running 8tit & alum tweets, Mosconi Audio 200.28 12" Ascendant Audio Chaos. amps 2 Digital Designs M4'zbox is a 4th order band passbatts. 1 XS Power D3400 under hood,6 D3100 in back2 XP 370 amp DC Power alts.MLA module 15+voltsAll in a 97 2door Tahoe LT2010 West Coast Reg. 140-149.9 Bass Race Champ Team Bass Hz
AmmoJammo Posted March 4, 2013 Author Report Posted March 4, 2013 I know nothing about an amps internals, but what I gathered from this thread: A amplifier is set to make X power. If you go over X amount of power it will go into protect. If you have more voltage going to the amplifier(less voltage drop), the amp will produce more. Putting it over that X amount, putting it into protect. If you have less voltage going to the amplifier(more voltage drop), it won't be reaching that X amount, not going into protect. Am I correct or am I off? The thing is though, that's what I would have assumed, but I haven't even been able to get the same SPL from the amp with the more stable supply voltage, as its simply more prone to protect.
AMI CUSTOMS Posted March 4, 2013 Report Posted March 4, 2013 The amp circuit is powered off the power supply in the amp, the more voltage you have on that circuit the faster the response time. So my guess is you are dropping so low of voltage that your amp protection circuit is slowing down to the point it isn't catching the impedance change OR your amp isn't making enough power on the current output stage to trip the amp into protect. When you add more voltage you allowing the amp to function as designed and it protecting itself. TEAM SOUNDQUBED -- TEAM SOUTH TEAM S.O.B. - Founder & Captain 3x Streetbeat World Record Holder 2017 MWSPL 1st place Mayhem & 4th Xtreme 4 2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4 2015 MWSPL 2nd place Mayhem & 4th Xtreme 4 2014 USACI 2nd place Streetbeat 5 - 162.6 db 2014 MWSPL 2nd place Xtreme 4 - 144.9 db 2013 USACI 1st place Streetbeat 4 - 161.9 db 2013 USACI 1st place Street Q+ - 162.8 db 2013 MWSPL 3rd Kaos2 & 4th Xtreme 4 2011 USACI 2nd place MOD 1001-2k - 160.0 db 2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db 2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest Best score to date 164.4 db - Termlab Outlaw Streetbeat 4 - 161.9 db Streetbeat 5 - 162.6 db MWSPL on Dash Legal door open (Music) - 162.5 db Sealed on dash Legal (Music) - 161.1 db - Termlab THE BLACK NASTY CURRENT BUILD & FAB The Black Nasty (6) 15 Rebuild Log 2012 (4) 15 Walled Sierra Build Log Evo X build log Facebook page The Black Nasty
mbdblue Posted March 4, 2013 Report Posted March 4, 2013 my best guess....OP is trolling HARD. From the information he has stated, he knows more than average about his setup and just jogging around the answer. Surprised this thread has reached 5 pages. AA-Atomic-Clif Designs-DC-Diamond-Digital Designs-Directed-Eclipse-Fi-Hertz-Hifonics-Kenwood-Memphis-Phoenix Gold-Pioneer-PPI-PSi-Stinger-Sundown-TC Sounds-Viper-Zapco
AmmoJammo Posted March 4, 2013 Author Report Posted March 4, 2013 you do not want to run those amps under 12.5 @.5 someone else asked me, so I'm asking... why not?
bdog Posted March 4, 2013 Report Posted March 4, 2013 im sure someone else is more qualified to answer this. its really hard on the amp as it trys to put out the same power so as the voltage drops the amps its consuming goes up combine that with low impedance and its just bad news REP
AmmoJammo Posted March 4, 2013 Author Report Posted March 4, 2013 but when the input voltage drops, the voltage rails drop, so the output voltage drops, which means so does the current.... it won't just draw more current to try and output the same voltage...
STEvil Posted March 4, 2013 Report Posted March 4, 2013 Z1's have issues... to say the least. http://www.diyaudio.com/forums/car-audio/221891-digital-designs-z1-amp-down-power-rails-there-output-isnt.html MickyMcD - "Capable of making some serious trouser flapping volumes at where's-my-testicles frequencies, the Servo-Drives used to be fairly jaw dropping..." Any time you have have a power wire next to your frame put some rubber hosing (or cut up an innertube) around it. The wire is bound to wiggle (due to driving or flex) and the casing will eventually wear through. Hammerdown... 1% no links to outside websites, business related FB/YT pages allowed.
AmmoJammo Posted March 4, 2013 Author Report Posted March 4, 2013 Z1's have issues... to say the least. http://www.diyaudio.com/forums/car-audio/221891-digital-designs-z1-amp-down-power-rails-there-output-isnt.html
bdog Posted March 4, 2013 Report Posted March 4, 2013 but when the input voltage drops, the voltage rails drop, so the output voltage drops, which means so does the current.... it won't just draw more current to try and output the same voltage... if you know everything why do you ask??? REP
