One post corroded and other fine? Causes
So I went to take out stock battery and drop in my D 6500. I had tsunami terminals on it... The pos terminal was totally fine and the negative was totally corroded, when I took it off the post was fine and not leaking and the wires were ok. What causes this and do I have to worry about this happened with my D 6500??? Thanks, will post a pic I took early if anyone wants it
The negative side will always corrode being under the hood exposed to the elements, if i'm not mistaken the gases escaping from the battery cause it to corrode.
Just pour some baking soda water on it and it will clean and neutralize it, just mix a tablespoon or two in a cup of warm water and pour it over the terminal.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
AGM batteries aren't corrosive because they're a dry cell battery.
2002 Dodge Dakota 4.7 club cab - Sold 2004 Audi S4 Avant
- Fi and Crescendo - Stock Bose System
- http://www.stevemeadedesigns.com/board/topic/147725-2002-dodge-dakota-end-of-the-road/?hl=%202002%20%20dakota
136.4 Sealed @ 29hz
137.0 Drivers window open @ 26hz
Do you have a vented hood?
The corrosion is from gases escaping from the battery.
Lead-acid batteries under the hood = no problem as long as the connection stays clean.
AGM batteries are sealed so they won't corrode.
IF you do see corrosion on an AGM, then your battery may have a small leak and it should be checked. This is especially important if the battery is directly inside your cabin.
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
Dash mounted O-scope
Highs Amp - PPI Art A404
DC Audio DC9.0K
2- DC Audio XL12m2
JUNE 2014 SOTM WINNER
SOTM BUILD:
No, Jeep Grand Cherokee...but the wires connected were a little sketchy lol, some didnt fit so it was a mess of wires being held in and wasnt clean...
  • Who's Online   0 Members, 0 Anonymous, 977 Guests (See full list)
