Camm.eng Posted February 25, 2013 Report Posted February 25, 2013 So of its ok to do different subs, what about doing the same series subwoofers, but two different sizes? Perhaps two 10" woofers and one 15" woofer?
Guest Posted February 25, 2013 Report Posted February 25, 2013 same model/size woofers or nothing. thats how i see it.
villarob713 Posted February 25, 2013 Author Report Posted February 25, 2013 Theyre 15s in a trunk. More flex with subs inverted back seats down Subs- 2 kicker cvxs 15 Amp- 1500 watt hifonics Wires-0g Deck-stock
CleanSierra Posted February 25, 2013 Report Posted February 25, 2013 And the box has now much volume? My suggestion is ditch the(likely) garbage box they're in now for a GOOD enclosure. What vehicle? Sealed box or ported? Im not the one you want to try to troll. Just a fyi for you.
CleanSierra Posted February 25, 2013 Report Posted February 25, 2013 Yea i got it from a friend. I need to do a custom one its pretty loud but i want more. Theyre just bridged wired parrelel Do you mean series/parallel? I'm unfamiliar with bridged/parallel... Im not the one you want to try to troll. Just a fyi for you.
bkolfo4 Posted February 25, 2013 Report Posted February 25, 2013 You can mix/match whatever you want if you already have them. If you are buying new, buy everything the same. Current system: 1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s Previous systems: 2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz. 1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
villarob713 Posted February 25, 2013 Author Report Posted February 25, 2013 Ported in a corolla Subs- 2 kicker cvxs 15 Amp- 1500 watt hifonics Wires-0g Deck-stock
Swordlordboy1234 Posted February 25, 2013 Report Posted February 25, 2013 Prefab box is not the way to go. Cvx's can be decent maybe but not the best choice. Electrical and headunits are your friend.... Along with a better box. That's your next steps. End of thread My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect?
KillaCam Posted February 25, 2013 Report Posted February 25, 2013 Just because you can doesn't mean you should. And the fact more than one person agrees does not make it a circle jerk, it makes it a bukkake scene and you're in the middle Chick took 3 shots of Jager, and then, pissed in my mouth.. B5 Passat Build Log
