RickyFriery97 Posted February 25, 2013 Report Posted February 25, 2013 hey guys, im bout to (finally) put my subs in my 2012 sierra setup will be two Sundown SA-8" V2 and two AQ750.1s my question is, would you strap the amps, or gain match? (subs are D2) this is a small daily setup. not looking for every lil bit I can get. 2014 Chevy Silverado Crewcab 1994 Chevy Full Size blazer
Watch the bass Posted February 25, 2013 Report Posted February 25, 2013 Strapping easyier than gainmatch. Did you have the 2 AQ 750, if not why not going with 1 1500 watt amp? "in the abundance of water, the fool is thirsty" Bob Marley
C-Fizzy Posted February 25, 2013 Report Posted February 25, 2013 Strapping is much easier. If you aren't chasing numbers then just strap. But why not a single 2200 or something? under construction I hate People with crappy primered cars rolling on hubcaps that are louder then me. u hate c-fizzy?
RickyFriery97 Posted February 25, 2013 Author Report Posted February 25, 2013 Strapping easyier than gainmatch. Did you have the 2 AQ 750, if not why not going with 1 1500 watt amp? Strapping is much easier. If you aren't chasing numbers then just strap. But why not a single 2200 or something? ive had the AQ750s for a while now but I will mostlikely just strap. I knew it was easier but didn't know if there was a major pro/con to it or not 2014 Chevy Silverado Crewcab 1994 Chevy Full Size blazer
bighossf150 Posted February 25, 2013 Report Posted February 25, 2013 I plan on gain matching my bc3500's Used to have a loud truck 2009 Corvette Z06, H/C/I, 150 shot, g force tune, 730rwhp/690rwtq 2013 F-150 limited, MPT Tune, leveled on 35"s
C-Fizzy Posted February 25, 2013 Report Posted February 25, 2013 I believe it's hit or miss. Some people gain, some people lose wih strapping under construction I hate People with crappy primered cars rolling on hubcaps that are louder then me. u hate c-fizzy?
RickyFriery97 Posted February 26, 2013 Author Report Posted February 26, 2013 If I was doing a larger setup I'd probably gain match But with 1500 watts even if it is a lost I doubt it would be noticeable 2014 Chevy Silverado Crewcab 1994 Chevy Full Size blazer
EricDoody95 Posted February 26, 2013 Report Posted February 26, 2013 Well, i am not sure but you should make sure that the amps are matched perfectly if they are sharing the same air space 2003 Honda Element Pioneer DEH-9400BT Big 3 XS Power D5100 Sky High CCA (2 Runs 1/0 Gauge) 2 XS Power D3100s 1 DC Audio 3.5k @ 1ohm. 2 DC Level 4's w/ XL Softies Custom Box tuned to 29hz CT Sounds 125.4 2 Sets of CT sounds Meso Components *North East Frequencies*
RickyFriery97 Posted February 26, 2013 Author Report Posted February 26, 2013 Well, i am not sure but you should make sure that the amps are matched perfectly if they are sharing the same air space if gain matched it will be using a CC-1 doesnt matter if they are strapped, i set the master and the slave will follow 2014 Chevy Silverado Crewcab 1994 Chevy Full Size blazer
