Joe X Posted March 5, 2013 Report Posted March 5, 2013 I read and re-read and he mentioned he is using a CVX, not the L7. The sketchup should have a round hole in the baffle. A Cvr
CleanSierra Posted March 5, 2013 Report Posted March 5, 2013 Read and re-read huh? I'd start he edited that, or just reading owned me. Whatever, either way, it's certainly NOT A square sub. The sketchup isn't accurate Im not the one you want to try to troll. Just a fyi for you.
Azzazel_99 Posted March 5, 2013 Report Posted March 5, 2013 square sub? Maybe he edited it right before i saw it but i only see round.
teamace24 Posted March 14, 2013 Author Report Posted March 14, 2013 Hey Joe, Im on the L port part of the box and i am wondering since i am not going to do the 45's anywhere do i still cut the L Port Internal Assembly Parts:Top to Bottom = 11 3/8 x 15 to 11 3/8 inches or do i cut that piece to 12 inches x 15 and keep the port width closer to the 2 7/8 running throughout the port? Or it does not matter and keep it like this? Thanks. 1st Setup(SOLD):2007 GMC YukonPioneer Avic F90bt Audiocontrol Epicenter2 Audioque SDC2.5 15 subs8.7 cubes at 37hz build DONEAudioque 1200d (Audioque 1200d Sold, similar performance to my ap1500)Diamond Audio Hex 6.5 Mids n TweetsCerwin Vega Exl 400 4 channel Bridged(also have MTX 4004 not being used)1 Run of power Knu Fleks 4 Gauge2 Cheap stock Battery setup2nd Setup (SOLD):2007 GMC YukonPioneer Avic F90bt Audiocontrol Epicenter2 15 Kicker cvx (maybe two SA 15 in future)7 cubes net tuned at 34hzAlphasonik Old school 1600rms (ap 1500d sold GREAT Budget amp)JBL 6.5 Power Series Components, Infinity Kappa 6.5 3 ways, and 2 Kicker KS Tweets (LOUD)Cerwin vega exl4001 run knu Fleks OFC 0 gaugeBig 3 done1 Odyssey 1500, 1 optima yellow top d31
Joe X Posted March 14, 2013 Report Posted March 14, 2013 Hey Joe, Im on the L port part of the box and i am wondering since i am not going to do the 45's anywhere do i still cut the L Port Internal Assembly Parts: Top to Bottom = 11 3/8 x 15 to 11 3/8 inches or do i cut that piece to 12 inches x 15 and keep the port width closer to the 2 7/8 running throughout the port? Or it does not matter and keep it like this? Thanks. Keep the port parts as given just round at the turn and both ends.
BassMunky Posted April 9, 2013 Report Posted April 9, 2013 pics of the box Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
BassMunky Posted April 17, 2013 Report Posted April 17, 2013 update? Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
Clarence Joseph Sales Posted June 4, 2013 Report Posted June 4, 2013 Sorry to hijack this thread. Originally i was planning to make a 4 15's c pillar wall for my xb but realized i can't get 14cuft without taking out the rear seats so i ditched the idea and saw this thread. I'm thinking of building 2 of this and place it side by side to form a wall. My question here is will it matter if i put the subwoofer closer to the port so that if i put my rear seat's backrest up, you'll still be able to see the subwoofers. Thanks in advance. To put this thread back on topic, to the OP, where you able to build this box? I would love to hear some feedback how this enclosure sound.
ncochran Posted June 6, 2013 Report Posted June 6, 2013 I have an 06 xb. If you don't mind losing the spare tire (you won't ever get to it anyway with 2 15s in the back lol)... There is another cube or two (as well as a couple inches of height and an inch or so of depth hiding where the spare tire and storage are back there. You still won't see 14 feet, but you can probably get close to 6 staying below the seat line, and about 10 without taking the seats out. Max dimensions without that false floor in there are roughly 15d x 37w x22h staying at seat line and not following angle of the seat. You can actually go 38w but it isn't the best idea as it leaves no room for power/ground wires (depending on where you mount the amp). The upper section can go 3-4 inches wider if you were building a wall. I have seen this done by essentially building 2 boxes and putting them together. The first box being built to the specs above, and the second being about 15d x 37h (could gain 1/2 a cube or so by going to 40 if you had to) x 18h, But as you said, you still won't see 14 cubes. 2006 Scion xB 2 Sundown SA12D2 Ported at 32hz 147 on non termlab (140-142 on TL) Currently in a walled 4th @ 50hz (not metered yet) Hifonics brz2100 Alpine Type-S Components Kicker 300.2 Big 3 / Skyhigh 1/0 cca Optima Blue Top 3 e8s ported at 32hz 135.1 sealed on dash @ 56hz 135.0 outlaw (I must have chosen song poorly lol) Build log 'Brandon15zzz', on 09 May 2012 - 3:13 PM, said: May have been clipping but none fucks were givin.
