Need advice on enclosure for DD 9512
i have a DD9512
Problem is the company advises tht the box be 2.5 cubes but i have alot more space
Intial box design would be 15" height, 36" width and 18" depth
for me to achieve 38 hz the port is 13.5 height, 4" width and 18" depth
net volume is 3.82 cubes i would like to kno if this is goin to work it is goin in a corolla wagon
ohhh and im using 2 5500 power acoustik BAMF is strapped config for now see how tht goes along
Vehicle: 2000 Toyota Corolla Limited S
Head Unit: DEX 99rs pioneer
Speakers
Sub treble/High mid : 2 1.4 inch throat 2080 18 sound drivers neodyium with wave guide
Tweeters: 2 Mtx dome, 4 APT eminence super tweeters
Mid Range: 2 18Sound 6" 6ND410 NEO,2 18 Sound 10" 10NDA610 NEO
Low Mid Range: 2 18 Sound 10 NMB420
Sub: 2 Z-12 V.3 D1 - Sundown Audio
Amplifiers
Sub treble/High Mid: MTX Audio TA5302 Thunder
Tweeters: JL Audio e4300 4-Channel
Mid range: MTX Audio TC3002
Mid range: MTX Audio TA7402 Thunder 7402
Low Mid Range: MTX Audio TA7402 Thunder 7402
Sub: MTX Thunder Elite 4001D
Alternator: 220amp mechman
Batteries: 3 D3100 XS Power
Lol when u say Bad wat exactly u gettin at bad in a good way or in a bad way?....i have read that the speaker over excorts and damages in too big of an enclosure?
and the amplifiers are temporary i used them on a atomic apx 12 strapped at 2 ohms and i got 148.6 dbs window down.
Speakers
Amplifiers
Like those amps are not good lol no other way to put it.
put the sub in 2-3 cubes. All i can really say. I still dont know what these subs like tbh.
148.6db means nothing to me too
A DD vs. Power Acoustik deathmatch, to avoid giving too much advantage to DD its placed on a 3.8 cubes box. Can't wait to see what happens :)
quad 4 gauge inputs!!! Im sure itll do fine. if dd can take a wall socket for 28 mins, 2 bamf 5500s .. meh. seriously just set the gains right and dont clip the hell outta it. itll be decent.
Setup:
2010 Hyundai Elantra
Factory Unit via 4 chan NVX LOC
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
Big 3. 2 Runs of +, 2 Runs of -
DD M3b and 2 12" AQ HDC4s
i wouldnt do those amps on that sub in a huge box either
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
so its a definite no no on the bamfs....i was thinkin to use them to break in the sub then probably shift to the mtx te4001d....wat do u guys think?
Speakers
Amplifiers
i mean its a cheap amp is all.. power is power... to a point i guess. but for 240 a pop, $480 you could not only simplify the install with a single BETTER amp. But likely put out more power, be more stable, and all for the same or about the same price. <---- When all 3 of those conditions are true you know that there is a better decision to be made.
Example:
And there are plenty options. and im not saying this is the best simply an example ONLY. Crescendo bc2000 around the same price, they used to be alot less. 2200w of clean power, very stable amp even under abusive ohm loads etc.
theres better decisions to be made, but if you like the bamf go for it. and post a vid as long as you like it who cares. but imo why spend $$$$$$ on subs and drop $ on amps?
Setup:
Xs D3400/ Xs XP3000
  • Who's Online   0 Members, 0 Anonymous, 2702 Guests (See full list)
