Need a box design
Ghoagland
I would like someone to design a box for a zvx 15 that is ported at @32hz and is 3 ft^3, the cut out is 13.9, sub woofer displacement is 0.17 ft^3 , and the mounting depth is 9.3.
It will be a trunk box so port back sub back and would like it to be double baffled, willing to pay for a good design thanks!!!!
Will be running an aq2200 in a 1995 toyota avalon xl
So here is a suggestion:
Enclosure Specifications:
Fb = 32.5 Hz
Vb = 3 ft^3
External Height = 17 in
External Width = 30 in
External Depth = 20.5 in
Port Width = 3 5/8 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
2 x Front & Back (3 parts) = 30 x 17
Left & Right Sides = 18 1/4 x 15 1/2
Top & Bottom = 30 x 18 1/4
L Port Internal Assembly Parts:
Front to Back = 14 5/8 x 15 1/2
Extension = 18 1/2 x 15 1/2
Assembly guide (generic dimensions):
Important notes:
- The 45s if you want to do them are 2 1/2" wide except the one/ones inside the port, if you want that let me know.
- All trunk boxes built outside the car need to fit in their way in not just have the right dimensions.
- The port needs 3 5/8" of free airspace in front of it for proper operation.
- Setting your amp subsonic filter to 28Hz is suggested.
Wow you went out of your way on that
A bit, if you want (and can) do the recommended high efficiency port shown, I need to provide a detailed diagram for it otherwise build like this:
  • Who's Online   0 Members, 0 Anonymous, 488 Guests (See full list)
