What in Gods name happened to my amp? Lol
Raptorman
Ive heard from plenty of people on here that shock tower ground is good. But even them i have the wire from the front batt wired to the same point. So it's almost liked a direct ground from front to back. Its like that because of the wire lengths i had.
1996 GMC Sonoma
Four Fi BTL Neo 18's In 2:1 6th Order Bandpass
2 Ampere 5k's @ .5
TEAM FI
TEAM #LITHIUMCANTDEMO
On 10/20/2013 at 0:37 AM, KillaCam said:
Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
It is sanded
1996 GMC Sonoma
2 Ampere 5k's @ .5
TEAM FI
Strut tower under the hood maybe, but ive never seen anyone use the one in the pacel tray's post. Still tho, why go from the front battery to that ground point, from the ground point to the rear battery? Id of ran it straight to the rear battery and then have a seperate ground wire to the frame.
edit: grr can't type lol
* Eclipse CD3200 with PAC SWI-CAN2 and SW-ECL2 Steering Wheel Controls Interface
* Pioneer D-Series Mids and Highs ( Fronts: TS-D1702C; Rears; TS-D1702R and Dash; TS-D1002R )
* Rockford Fosgate PBR300X4 ( Mids and Highs Amp )
* DC 3.5k with Dual Inputs; Custom Plexiglass Backing ( Sub Amp )
* Rockford Fosgate Balanced Line Driver
* One FULLY LOADED ~ 10" DC m2 XL
* Custom Built Carpeted Ported Box Tuned to 32hz. Single Chamber With Volume of 1.44618³ ft ; 1.13216³ ft After Displacement
* Custom Built Carpeted Trunk Wall with Added Fans for Amplifier Cooling
* MechMan 240a High Output Alternator
* KnuKonceptz Krystal Kable RCA Cables
* Upgraded Electrical With 1/0 KnuKonceptz Kolossus Fleks Kable and 1/0 Sky High Car Audio Cable
* Five Exide Orbital ORB34M Marine 12 Volt Batteries
* PowerMaster XS D3100 12 Volt Battery
My 2008 Chrysler 300 Limited - SuperCharged 3.5L V6 - UBL
My Old 2005 Ford Taurus - CarDomain - Vehicle Was Sold
Okay so here's the update. I was driving to work. And I was planning on reaching up and feeling the terminals once I was here to see if they were hot or anything like that. Well I ended up having to pull over about 20 minutes into the drive because I could smell burning plastic. So I'm just like what the fuck, then I look at the terminal, and it's sagged even more and I touched the plastic with the tip of my finger and it was like hot glue, lol..
Then I noticed the wire jacket was melting as well. The entire length of the cable coming from the distro block was scorching and I could just pull the wire out of the terminal. (This was the power wire btw) the wires going to the distro block, battery, etc are all perfectly normal temp and condition.
Edit: I also made sure that NO WIRES were bridging or touching, and none were. Since I could pull the wire out easily, I am thinking that it wasn't tightened enough and wasn't getting enough contact. I don't know. I'll have to take the amp out and cut the plastic away on that side of the terminal so the wire can be fit back in.
1996 GMC Sonoma
2 Ampere 5k's @ .5
TEAM FI
The amp has the power/ground wires disconnected for now until I can work on it.
1996 GMC Sonoma
2 Ampere 5k's @ .5
TEAM FI
its a bad connection thats it
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
Didn't watch the video. Where is amp ground?
Amp grounds to batt, which grounds to a rear shock tower post, then I have a length of 1/0 OFC coming from my front batt negative to the same post, so they meet there. It's like that because the length of wire I had was too short to have it laid out like I wanted it to.
1996 GMC Sonoma
2 Ampere 5k's @ .5
TEAM FI
Yep, that's what I'm hoping it is. Totally fried my piece of Welding cable, it's all blackened and it's like crushed and falling apart. Gonna put another piece of wire in and really clamp down on it this time and go out and wang on it and watch the terminals for about a half hour.
1996 GMC Sonoma
2 Ampere 5k's @ .5
TEAM FI
  • Who's Online   0 Members, 0 Anonymous, 1793 Guests (See full list)
