tuned in... should wall that bitch off, bitchs loves walls!
are you doing a double baffle on the box?
My build log http://www.stevemeadedesigns.com/board/topic/143943-2001-mustang-gt-system-rebuild-box-build-pics-updated-61512/
2001 Ford Mustang GT
4.6 SOHC 380HP
270 amp Mechman alt
2 12" Treo SSX custom built.
6.47 cu ft, tuned to 32Hz
2 hifonics Brutus 2400.1, strapped
1 optima yellow top
1 Kinetic HC1800
14.4v @ 29Hz, 2k RPM
over 100ft 1/0 XS flex wire
Big 3 in 1/0
100sq ft fatmat deadener
145.3 on music, 142.6 sealed on music
Stop being a pussy and wall it off.
I hate when my google breaks too
I think the usps must be ran by a bunch of drunk ass oriental midget monkey's on methamphetamines.
Are your power and grounds going into the amp different gauge wire?
They use to be lol. I got excited when i bought the amp and didnt change the ground wire. Its all 0 gauge now :)
Box is complete and the glue is setting. I used Gorilla wood glue. same as i used on my last box. Seems to work pretty good. I glued to pieces together at a 90 degree angle and tried standing on it (225 lbs) and it didnt even budge
I was almost ready to put it in the truck and forgot the seal the hole where i ran the wires through the box -.-
cool I'm running 2 sd-2 10d4 in my single cab dakota shit slams will be watch the dakota build
02 dodge ram 1500 reg cab 3rd gen
2 sundown sd-2 d4
soundstream rub1.2500 amp
all sky high car audio-fuse,fuse holder,wire,ring lugs and rca
flex tech
box design by Joe X
supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch
04 5.7l hemi motor swap and made it an slt eletric everthing
youtube channel-http://www.youtube.c...43?feature=mhee
http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
Im so eager to hear how this sounds. This glue takes to long to dry. I want to see how much of a difference a prefab box is compared to a custom built box.
there should be a noterable difference in them.
you built the box that is recommanded for that sub. prefab box are just "in general" boxes.
staying tuned in!!
4.6 SOHC 380HP
270 amp Mechman alt
1 optima yellow top
1 Kinetic HC1800
Big 3 in 1/0
Ya i did research on the box it was in. It was 1.1 cubes OUTSIDE space. Not accounting for port or sub displacement. And tuned to 50 hz -.- Ive had trouble hitting anything low and i still moved the windsheild wipers a little :) Hopefully get some more flex now.
  • Who's Online   0 Members, 0 Anonymous, 3341 Guests (See full list)
