Blowing Fuses Problem Help Please.
alright so my system worked fine until i added a schose 500kfarad capacitor it still worked great after i added it, but last night i decided to rewire my wiring kit to a 4gauage (not the problem) anyway one i got everything ran i went to hook up my capacitor again and it kept making a huge spark then blowing my fuses on my amp and keeps doing it everytime i hook up my power wire off my capacitor into my amp, any help would really help, thanks for the assistance.
Cory.
Caps dont rlly help with electrical im sure you will hear when someone chimes in but could power ground be reversed? And im pretty sure when using caps u have to pull out the fuse on the power wire first to charge it and make a jumper where the fuse was fir a sec i may be wrong though
My setup,
Digital Designs M80
3 Re audio 10's ported tuned to 36 hz
Kenwood x-696
SHCA 0 gauge
Polk audio coax running off hu
It seems like your cap discharged itself and by doing that there would be no power stored in the cap. When you connect the power direct to it, its like a dead short so it will blow. You should have had a charge card with the cap that you need to connect PRIOR to hooking the cap up to the amp and cap to the charge/ground wires. If you don't have the charge card just take a simple automotive bulb like one under your hood and wire it in series with the positive wire and then for the negative just wire that to the battery -. When the light goes out then you are fully charged and can hook the cap up.
2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
Did the fuses on the amp itself blow?
That could be an indication of the power wires being swapped. I know you said the wiring isn't the problem, but I've heard that many times, and it turned out something was wired wrong.
I know a guy who did that on a CV amp, the fuses blew and the amp was toast.
