ToNasty's Silverado (Linear Power stuffs)
Should go pretty fast from here on out
So, i should expect actual progress??
:peepwall:
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
Piece by piece you buy.to me that's fine ..at least you are getting good equipment.
No reason to spend money on poop. By the way the alt is a dc 270
You have the 4.8 or the 5.3L in the Silverado? It's amazing how many more options are available for the 4.8/5.3/6.0 than the 5.7L I have in the Hoe. I just pulled the trigger on a Mechman 240 Universal today, gonna leave the stock one in there to run the truck and make a bracket for the 240 to run the system.
01 Chevy Silverado X-cab
2 Sundown Z18v4 walled on 2 Lanzar Opti 7k's strapped at 1/2ohm = each amp wired to 1/4ohm. Havent checked impedence rise so not sure what they are actually seeing. 6 group 31AGM's.
2-Eclipse 34230's each one running 2 Eminence 6.5" Beta 6A. These are beastly mids rated at 350w program power. I was skeptical but the eclipse amps are 370w x 2 and when there was 4 mids on 1 amp I could push it into thermal protect within a song so added the 2nd amp.
Eclipse 4212 running 4 CT sounds Meso tweeters. and 2 DLS ultimate tweeters up high to raise the soundstage.
96' Ford F350 4wd 4d long bed 7.3 diesel with 91k miles. Will be the sound quality rig if I can ever find the time.
My 4.8 is quick and gets good mileage. Even with the 200K, I'm still getting 20 MPG on the highway. I DO wish I had the torquey grunt of the 5.3 though.
I guess I'll tune in to this build, I've lurked on it long enough :P
