What is the best way to secure subs in a box?
Nick580
Sorry, but what is aircraft cable?
yeah t-nut and aircraft cable if security is an issue.
T nuts are cool until they come loose and then you can't get the sub out
Have had it happen even with the glued in
That's when you seriously start contemplating if you really like your baffle enough to not just take a saw to it...
Krakin's Home Dipole Project
http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370
Krakin, are you some sort of mad scientist?
I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
What you hear is not the air pressure variation in itself
but what has drawn your attention
in the two streams of superimposed air pressure variations at your eardrums
An acoustic event has dimensions of Time, Tone, Loudness and Space
Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears,
thus no formula can achieve a definite effect for every listener.
It sounds like this happens often.
It happened to a little 12" sealed box I had so I had no problem at all just unscrewing it from the side walls and kicking it in.
Wow... well im not going the t-nut route then.
I use these. They work great. Never had a sub come out on me, even using the same screw hole 6-8 different times
http://www.homedepot.com/p/SPAX-14-x-2-1-2-in-Blue-Zinc-Multi-Material-Phillips-Square-Screw-10-Per-Box-4101010600601/202041020#.UTlulxx_B8E
Cool. I am using zinc screws right now and they have worked so far.
aircraft cable is high wound steel cable. You cant cut it with ordinary cable/rope cutters. Only way is torch/plasma cutter or grinder. cheap and reliable.
I just use a regular 2" wood screw I think....maybe its a coarse thread drywall screw but a little thicker
Works fine on all the 60lb subs I've used mounted vertically
Team Flex Issues
  • Who's Online   0 Members, 0 Anonymous, 1112 Guests (See full list)
