Xscorpion Voltmeter
I am really stuck.. So the voltmeter has a red wire and a black wire. So I took the red wire to the power on my amplifier and the black to ground it would be the right reading but the voltmeter would never turn off, even if the car was off. Then I did red to my remote wire but that just gave me a reading of my hu, which I don't want. But that would make my voltmeter and amplifier stay on when I did that. I'm so stuck. I don't know what to do, any suggestions?
Thanks, Bryan
___________________________________________________________________________________
-1997 Oldsmobile Cutlass Supreme Coupe-
-2 12'' Alpine Type R's-
-Sony xPlode Head Unit-
-Planet Audio AC2000.2 Amplifier-
Anarchy Series 2-Channel Amplifier
RMS Power Rating
2 ohms: 700 Watts x 2 chan.
Bridged, 4 ohms: 1400 watts x 1 chan.
I have the same problem. Idt there is really anything to do. Maybe run ground to remote wire?
My SPL to SQ Build Log
Vehicle:
1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT
5.2L V8 Magnum 3.5L V6
Stock Alt
Equipment:
Headunit- Alpine CDE-147BT
Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel
Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D
Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12
Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy
Mids- Dayton Audio Reference 4" Full Range Drivers
Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5"
Processor- MiniDSP 2x4
RCA- 6 channels of SounDrive HF series
Wire- EB Flex 2/0
-Member of Team SounDrive
It should have an auto off on it, but mine don't turn of either, so i put a switch on the 12v wire.
Build log: Click
Feedback: http://www.stevemead...xbccp-feedback/
03 Chevy Blazer
- IPad Air 2
- ALPINE Head Unit
- 4 DC XL 18s
- 2 DC 3.5k
- ALPINE TYPE R 5.25 COMP
- 3 ALPINE TYPE R 6.5 COMPs
- DC 175.4
- DC HO Alt
- D3400
- 4 XP3000s
- KNU 0ga
- 60 SqFt Damp Pro
Lots more...
I tried that and had no luck. It sucks lol.
I'm guessing I'm gonna have to add a switch. Cuz I can't figure out anything else. Lol. Damn. This really does suck.
RMS Power Rating
use a replay. remote turn on hooked to 85 or 86, ground the one the remote turn on isn't hooked too 85 or 86, post 87 with be power from amp, post 30 is power going to VM.
if you get a relay, the output of the relay is turned on by either ignition or the remote turn on, and it is a 12v from which ever location you power the relay from.
So if you get a relay, power and ground off the amp, remote from the headunit, then you can connect the ground of the volt meter to the ground of the relay and the positive to the relay out and it will measure your voltage at the amp.
This is how mine is, i can tap into it. (this a old pic, it is different but really close.)
then you wire the postive of the relay to the amp positive location and the ground to the amp ground location.
  • Who's Online   0 Members, 0 Anonymous, 1072 Guests (See full list)
