smelling my speakers after dd-1
The effective way to set using a bass knob is to make sure it is turned all the way up. Then set your gain. This way when you turn the bass knob up all the way, it won't send the amp into clipping.
Setting an amp and then using the bass knob to boost the signal defeats the purpose of setting amps to begin with.
I tried playning around with boost on my deck and amp with the DD-1 conected and it clipped instantly. I wonder if Iphones clipp with there volume all the way up ? i also use aold IPhone 4 for my music. I dont smell my subs but they sounded weird...wonder if it has anything to do with it....
2006 Dodge Ram 1500
Xs3400
1500BDCP
FI BL 12
3sq @ 32hz
Rockford t675
T400.2
Stinger Deadner
Build Log Here
again I set bass knob to middle as per instructions from d'amore I think cause of problem is with changing settings on head unit, tonight I will hookup dd-1 again with settings the way they are and see what its doing, I don't see why if steve said you can change them back to your preference after you are done setting everything
so few hours ago I turned down bass on head unit made it flat basically like when you find where the head unit clips with a 0db tone, drove around I know head unit clips at 56 I had turned up to 40, smelled my speakers again and then bass stopped, I fried the amp. no more output from speaker terminals, this is third time this has happened with this amp, ive taken it to mtx and had it repaired each time. im frustrated and don't know what I have done wrong, this amp is 1 ohm stable and im pushing 2 18 btls at 4 ohm unclipped. I was going to come home and take pictures of the dd-1 and being unclipped but no point now since I have no output from amp
how is it that I smell the speakers but the amp fries, a long time ago when I did not have my amp tuned properly, like 3 or 4 years ago,pushing an fi q 12 at 2 ohm I blew the voice coil so I know the smell but then that started poppin and fizzled out real quick as you know, but right now I smelled my subs but they sound perfectly fine ,so am I frying the coils or not
also don't know if its a factor to frying things but I do not have big 3 or HO alt or extra batteries im only running stock alt with yellow top and 1/0 to amp and it was suckin my battery hard
you sure you're not smelling the amp
This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
  • Who's Online   1 Member, 0 Anonymous, 1454 Guests (See full list)
