does this seem ok for 4 OA 15s?
jeffrm
Will be walled off in my 02 Silverado. looking for some good lows
03 tahoe z71
4 death penalty 18s
2 ampere audio 3800s @ .5 each
18v
156.7 @ 35hz
158.5 @ 50hz
Looks within specs, the port looks ok, the extensions should be around 3.5" long, the port and side panels would need bracing as well. threaded metallic bracing can be used for excellent results.
All my extra bracing will be 1/2" all-thread
03 tahoe z71
4 death penalty 18s
18v
156.7 @ 35hz
158.5 @ 50hz
if you can get closer to 16net @ 32 it will give you a flatter response,
youll just have to be a bit more careful at full tilt
idd drop the port size down if you cant go larger in the box to high 14 15flat
Im looking for straight output. Obsidian only recommends a max of 3.75per.
03 tahoe z71
4 death penalty 18s
18v
156.7 @ 35hz
158.5 @ 50hz
then why you tuning so low, get it up between 37-42hz
youll be supprized how musical you still are upto or at 42hz
side note
Obsidian only "recommends" a max of 3.75per
but if your chassing output no need to go any higher
  • Who's Online   2 Members, 0 Anonymous, 1075 Guests (See full list)
