Why subwoofers need the same impedance
Jskiles
Well I've seen the question on different forums asking if they could wire subwoofers of different impedance together. Well technically you can but you will run into problems escpecially if they are in the same box. I made this little RVIP chart and calculated with some good ol Ohms law and Watts law to give you an idea why. The first picture is series and the second one is parallel.
As you can see in the chart that sub 1 is taking more power than sub 2 and vice versa in the second pic , So if they were be in the same box i'm sure there would be some cancelation issues and other things to happen.
I'm almost certain this is why it won't work but if you have anything to add feel free to do so.
2010 Kia Forte Koup (Slow Build)
2 Sundown SCV-3000D
2 DC XL M1 with PSI recones
Focal R-165s2 on Orion 4800-HP
Kenwood KDC-X798
Knukonceptz OFC 1/0
Audiotechnix,Fatmat and Q-mat Deadener
XS power D3400 up front 3 D3100s power in trunk
Stock 110 amp alt
2013 Scion TC
2 Dc lvl 3s with xl coils on Soundqubed 2200
Sundown components
AA 50.2 for components
Pioneer FH-X700BT
Knukonceptz OFC 1/0
XS Power D3100 up front D925 in back
Mechman 240 alt
http://www.stevemeadedesigns.com/board/topic/189911-2013-scion-tc-build/ <Scion TC Build
http://www.stevemeadedesigns.com/board/topic/174094-jskiles-forte-koup/ <Slow Kia Forte Build
http://www.stevemead...ockUserAgent__1 < Old build 2005 Equinox
That's for subs wired in series, if they were wired in parallel voltage would be the same and currents would be different. the power figures would be about the same as you have calculated above.
I have posted this in many threads on the subject.
Different impedances = different power distribution.
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
I'll do one that is in parallel as well, but what ive calculated in parrallel it's still double the watts. I'm just doing these for simple understanding. I'd also like tho know other reasons as well
2 Sundown SCV-3000D
Kenwood KDC-X798
Knukonceptz OFC 1/0
Stock 110 amp alt
2013 Scion TC
Sundown components
Pioneer FH-X700BT
Knukonceptz OFC 1/0
Mechman 240 alt
It will be double. Voltage is the same, current is double to one vs. the other.
Power = voltage x current
Current system:
Previous systems:
It's an annoying question isn't it.
2 Sundown SCV-3000D
Kenwood KDC-X798
Knukonceptz OFC 1/0
Stock 110 amp alt
2013 Scion TC
Sundown components
Pioneer FH-X700BT
Knukonceptz OFC 1/0
Mechman 240 alt
It's more like it comes up frequently.
  • Who's Online   1 Member, 0 Anonymous, 1185 Guests (See full list)
