So i just started having a problem with my bass the other night, when i start bumping the bass will cut off for a bit then come back on. yesterday i went out to see if it would still do it, started bumping for a bit then it did it again. i noticed that when it did it my cap goes down to 8 volts and has a steady long beep. i checked my voltage at the battery before and after this happens and it's fine. went to the shop where i had it done and he checked my grounds and told me that looked fine.(didn't go any deeper than that unless i wanted to pay for time). Question is, based on my cap doing what it's doing could it just be the cap? or could my amp be on it's last leg? I've had this set up for almost 2 years and the amp is cheap so i wouldn't be surprised if it was the amp. any help or suggestions are appreciated thanks.
Recap: cap drops to 8 volts after bumping for a bit
had equipment for almost 2 years, first time having a problem
system was tuned with o-scope
power wire looks good, ground looks good.
Mk4 jetta 2 point slow
Kenwood KDC-X496
hifonics HFI-1000d
Obsidian 12 in a 2 cube box 34hz
some shitty orion 4 channel
2 pairs of infinty components
I had this same problem, I looked at the terminals on the cap and after taking the top plastic shielding off I found that one of the terminals was broke almost in half, might be the same problem? If not just get a second battery, makes a world of difference.
Take the cap out. See how that goes.
1996 GMC Sonoma
Four Fi BTL Neo 18's In 2:1 6th Order Bandpass
2 Ampere 5k's @ .5
TEAM FI
TEAM #LITHIUMCANTDEMO
On 10/20/2013 at 0:37 AM, KillaCam said:
Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
yea i plan on doing that next, when it's not snowing lol.
Kenwood KDC-X496
hifonics HFI-1000d
This.
No drop at the battery and only drops at cap, I would remove it first. If it happens at the battery after that, then check the battery and connections.
10501650_10203332501847103_1859383749711
Blown
Check your ground it's loose
my ground got retightened at the shop yesterday.
Kenwood KDC-X496
hifonics HFI-1000d
Pics of ground....just cause a shop did it doesn't mean its right unfortunately
This, also was the body sanded down before the ground was bolted onto the chassis?
  • Who's Online   0 Members, 0 Anonymous, 559 Guests (See full list)
