Where to buy tires online at
After three years and two court cases I finally got my 26's from the tire shop that held them ransomed from me for the past 30 months. The rims are brand new however because they ordered the wrong offset (+18 instead of +30) I'm now stuck with rims and tires that I can't mount on the truck without doing some trimming. I'm trying to avoid the trimming of inner fender as much as possible, so I was told that by going down a size are two in tires might help with the rubbing but add to a rougher ride. So I'm looking for any places online that I can find tires at and compare online prices to local tire shop prices.
I currently have Lexani LX4000 305/30/26 series tires and I'm wanting to go down to a 295/30/26. I don't even know what brands of tires I need to look at. I have bad roads here where I'm at and hate having to go down in tire size, but I can't afford new rims right now and I just finally got these and would like to have one spring summer on them.
2007 Chevy Suburban LT1
Pioneer AVH 5700 DVD
Diamond Audio D3 6 1/2 components
Kicker 06ZX650.4 amp
Kicker 06ZX2500.1 (x 2)
DC Sound Lab Level 4 18's with Level 5 coils
Autotek Mean Machine 400.1D (replaced)
Soon to come:
rims
body kit
flow master pipes
Confuscious say "he who say it can't be done shouldn't be bothering man busy doing it"
Now feel free to go crawl back under that rock and leave this to the professionals....
tires.com with the road hazard warranty. i only buy my tires from here
if nothing changes, nothing changes
You don't know what you don't know, till you don't know
They didn't have tires there in 26's for my truck. Thanks for the link though
Soon to come:
rims
body kit
flow master pipes
Tirerack.com
www.dcsoundlab.comDCforum.jpgyoutube video's kbsmoker2011 MECAOH AS3 Champ 147.5OH DB2 Champ 125.9WF AS3 3rd 147.3WF DB3 2nd 128.3
SystemPioneer AVH-P4300DVD2 sets Fusion Encounter 6.5 componentson Crunch Ground Pounder 1200.418" DC NEO
on DC 5.0KKnukonceptz 1/0 through outBig 3 all 1/0XS D6500under hood D3100 in the backMechman 270....rebuilt by Ohio Generator :)
how about some wheel spacers instead of spending new money on tires
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
Craigslist.... I just bought some for my 22's brand new for about half off. If I where you, I would look around for some used tires in that size to make sure that they will fit. Its a lot cheaper to buy up 300 worth of used tires, then to make a purchase of 2000 for new tires that may or may not even fit. Go down to a couple of independant tire shops ( not a wheel works or big o) and see if they have any there.
2006 GMC Yukon
Pioneer HU
SHCA ran throughout
Crescendo BC3500
One 18 AA Mayhem in a 4th order
ZED Levithian 6 channel
Rainbow Dual 6.5 comps ran Active
http://www.stevemeadedesigns.com/board/topic/155628-matt14s-yukon-mayhem-in-a-4th-ordernew-amps-and-bats/page-3
Because the offset on the wheel is already off by a factor of 12. The 07 to current model GM trucks have a +30mm offset and the rims I have is +18. So they already stick out to the point of causing rubbing. I need the smaller tires to reduce some of the rub. I'm trying to avoid cutting my truck but I've got the feeling that I'm probably going to have to do some inner fender trimming.
Soon to come:
rims
body kit
flow master pipes
Thanks for the suggestion. I've already hit up CL this morning. Don't want to buy new rims and tires and that's all that's out on CL in my area right now.
Soon to come:
rims
body kit
flow master pipes
onlinetires.com 295/30/26 starting at $125 each
2016 Ford Explorer
2014 Ford F-350 crew cab
2012 Cadillac CTS-V coupe
2008 Lexus GS430
call Paul at thewheelkings.com, he's got a semi truck load of Lexani tires in stock. Surely he will have the size you need.
