fyi, you will want 600-1krms for each SA 15 if you do those, 1 2500 on 6 would be loud, but not near enough to really get life out of them.
Yeah, I totally agree with this. It all boils down to your budget.
If you are starting from scratch, don't forget to budget for electrical stuff (wiring etc)
Because the bc does close to 6k for cheaper vs the sundown. Not bashing on just looking at what I see on the website
but you aint running 0.25 daily are you
ive seen the bc clamper at [email protected] 14v 1900@2 14v and 3900@1 14v
there site clames 3850@1 13.8v and [email protected] 13.8v
ive herd of people running 0.25 burps but never daily
+ they dont warrant 0.5 daily anymore
where as the aq3500 is 4300@1
well worth the extra 100 if you ask me if your getting the d2 for a 1ohm final
also dont rule out dc i havent run any but from what others are clamping them at they seem to be about 600 over aq and sundown
this was copied from another post jacob did
Power Test Completed.
I know someone will ask these questions SO READ THIS FIRST :
1) AQ-3500D Tested First - Battery Bank had a charge for several hours from our bench power supplies
2) SAZ-3500D Tested Second - Only a few minutes behind the AQ-3500D Test
3) THIS IS WHY the 3500D had much more voltage drop, I had the entire surface charge gone from the batteries
4) Both amps set wide open to be apples to apples.
AQ-3500D POWER TEST:
http://www.sundownau...0D/CIMG2679.MOV
AQ-3500D VOLTAGE TEST:
http://www.sundownau...0D/CIMG2681.MOV
POWER : 2400 Watts
AMP VOLTAGE (measured) : 71 V
AMP CURRENT (calculated) : 33.8 A
ACTUAL IMPEDANCE (calculated) : 2.1 ohms
SUPPLY VOLTAGE : 14.22 V
SAZ-3500D POWER TEST:
http://www.sundownau...0D/CIMG2682.MOV
SAZ-3500D VOLTAGE TEST:
http://www.sundownau...0D/CIMG2684.MOV
POWER : 3020 Watts
AMP VOLTAGE (measured) : 77.2 V
AMP CURRENT (calculated) : 39.11 A
ACTUAL IMPEDANCE (calculated) : 1.97 ohms
SUPPLY VOLTAGE : 11.99 V
do some research, (this is not the only forum around)
they are all in the same price bracket give take $1-200
and base you desison on you final ohm load and box size
  • Who's Online   0 Members, 0 Anonymous, 511 Guests (See full list)
