Noticeable gain from sealing off?
I know a lot of people don't prefer using expanding foam on their rides and I'm somewhat one of them... How much difference CAN it make on earometer/spl meter. I know it depends on the setup, but I'm just wondering if its worth the time/mess/cost (not money)... I've done a firing forward sealed setup, and I'm in debate. I still get a good bit of trunk rattle....
Think it will be noticeable difference to use foam?
E0AC38EF-8947-4C3C-B071-BA14723CA9DC-379
BC057508-61BA-4ED1-A92D-A2110B20822F-435
D7BD8C81-9BB8-442C-92AC-FEF3A2D179AB-379
Still have a little more work, looking a little poopy still...
IMO sealing off makes a huge difference on how clean and accurate the bass sounds vs rear firing stuff. I will find out this summer about sealing off :D
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
honestly sealing it off with expanding foam is the way to go, alot of people will line the area with tape and foam on top of that....
seeing that you cut apart the opening for the backseat, it isn't going to hurt you much to foam it and seal it off completely...
http://www.stevemead...cherokee-build/
2005 Jeep Grand Cherokee
Alpine CDE-hd148bt
Alpine PKG-RSE2
PRV Audio (4) 6MB200 front/rear doors
PRV Audio (4) TW350Ti dash/rear doors
Kicker KX350.4
Obsidian Audio (1) 18 D4 v2
revamp (2) Stereo Integrity HT 18d2
DC Audio 1.2k
5.25ft^3 tuned @34hz
revamp Infinite Baffle Cpillar
AudioTechnix 60mil deadener
KnuKonceptz & SkyHigh wire (complete setup)
went trom 80% sealed to 100% and not only where the lows way clearer and louder but i could pull a little hairtrick and NO trunk rattle
50hz and up kinda was lost but i only listen to decaf/altered music so i didnt mind it
down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups
^^ Cant wait to swalllow Ghost's babies
I just sealed off from the start. I didn't want trunk rattle.
This is how I did it.
Made some side panels, with foam rope to seal it off.
Foam
(top)
And Bam
'01 Dodge Stratass Sealed Trunk Build Log
2008 Honda Fit Sport Build Log
On 10/3/2013 at 10:00 AM, ROLEXrifleman said:
Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
OP, Hella nice job. You went from not knowing if sealing off was worth the trouble. To looking like you've been sealing off trucks your whole life. Like I say "Shit Ain't hard".
  • Who's Online   0 Members, 0 Anonymous, 597 Guests (See full list)
