Keep Blowing Subs, Advice Needed
Kyle J
Most radios don't put out full output unless the level is set that way
i have yet to see this hmm maybe when i upgrade to a higher end alpine i will see it but my kenwood starts the distortion light at 13/15 on subwoofer level
skar sk2500.1
0 gauge power and ground kunukonceptz
alpine HU
vxi65 components on BA gt-275
new build log -> http://www.stevemeadedesigns.com/board/topic/150642-project-d-kon-deathcards-build-log/#entry2148821
2 x-15 sundowns
singer alt, odyssey bat, and maxwell ultra caps
Bottom line is you are turning it up too loud.
You can set the loudness however you want, and you can turn the bass boost up if you like, but then you cannot turn the volume up as high.
You are trying to get more bass out of your system than it is setup to produce. . .
Are you thermally killing the subs or ripping them apart mechanically?
Thermal. They look fine but of course the dust cap was warm so I'll assume the voice coils were toasted lol.. Wish I would've made this thread 4 Clipped subwoofers ago. $300 down the drain man lol.. I'm in High School and it took me forever to get everything all for nothing. Just installed my D3400 in the rear too haha
what do the tensil leads look like i believe they should be silver some1 correct me if i am wrong
skar sk2500.1
alpine HU
2 x-15 sundowns
Did 412cvx design your box? :)
Turn it down lol, just like everyone else said. Flat eq and all that fancy junk off. Is your voltage staying above a minimum of 13.0 AT the amps when your playing full tilt or whatever you blow them at? You could be reading 13.4 at the battery, but that could drop down to 12.6 or less at your amps.
Voltage was good because I was driving at the time (stock 120a alt) but I could be wrong because I have a cig lighter Stinger Volt Meter, not one directly at the amps yet.
My High School Build-
07' Civic Si Sedan
Head Unit: Pioneer DEH-3500ui
Sub Amp: (2) Hifonics BRZ1200.1D's
Full Range Amp: Pioneer 75.4
Subs: (2) Skar Audio VVX12 V2 D2's
Speakers: Pioneer 4-Way's x4 (RF's soon)
Tweeters: (RF's or Alpine soon)
XS Power D5100R Upfront
XS Power D3400 in Trunk
Knu Kolossus OFC 1/0 Power & Grounds
Big 2/3 Wiring with 1/0 Gauge (Alt. is left)
They were silver but I haven't taken the subs out of the box again since blowing them so I'll see I guess.
07' Civic Si Sedan
Just turn the stuff down man. You didn't use the DD1 properly
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
  • Who's Online   0 Members, 0 Anonymous, 450 Guests (See full list)
