Slammin sonoma Posted April 8, 2013 Report Share Posted April 8, 2013 Doing a box for 4 10" re audios prolly gonna run 2000+ watts rms my ??? is should i double layer the box, just the part where the subs are, or do i need to double layer at all?? any help is greatly apreciated! mercury milan 1x SA-15 1x db Drive 1000.1d 1x db Drive 80.4 nexus 7 in dash fosgate in doors and deck Id imagine youd get alot of help if you posted in the right section Link to comment Share on other sites More sharing options...
SnowDrifter Posted April 8, 2013 Report Share Posted April 8, 2013 What are the dimensions of said box?It would never hurt to do it ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
Slammin sonoma Posted April 8, 2013 Author Report Share Posted April 8, 2013 deminseons are still in the works however its predicessor desighn was 52w 11d 24h (all in) thinking about makeing a slanted box and inverting the subs on the top a few designs are bouncing around the noggin mercury milan 1x SA-15 1x db Drive 1000.1d 1x db Drive 80.4 nexus 7 in dash fosgate in doors and deck Id imagine youd get alot of help if you posted in the right section Link to comment Share on other sites More sharing options...
reelfish92 Posted April 8, 2013 Report Share Posted April 8, 2013 What model RE woofers? I am guessing a total of 2,000w rms combined? Double sub baffle and maybe a brace in the middle. Team Flatline AudioBuild Log: http://www.stevemead...-s10-build-log/YouTube ---> http://www.youtube.com/reelfish92 Link to comment Share on other sites More sharing options...
Slammin sonoma Posted April 8, 2013 Author Report Share Posted April 8, 2013 im thinking re sex but depends on the electricals i want re sxx doing about 4krms mercury milan 1x SA-15 1x db Drive 1000.1d 1x db Drive 80.4 nexus 7 in dash fosgate in doors and deck Id imagine youd get alot of help if you posted in the right section Link to comment Share on other sites More sharing options...
Pioneerchuck Posted April 8, 2013 Report Share Posted April 8, 2013 Depending on the subs and if you do any bracing or not, Id say youd be better off doing a double baffle with a brace in the middle would be perfect for you. As for a slanted box with inverted subs, again depending on the subs I'd be afraid the subs would make the box topple over...Lol Link to comment Share on other sites More sharing options...
Slammin sonoma Posted April 8, 2013 Author Report Share Posted April 8, 2013 Depending on the subs and if you do any bracing or not, Id say youd be better off doing a double baffle with a brace in the middle would be perfect for you. As for a slanted box with inverted subs, again depending on the subs I'd be afraid the subs would make the box topple over...Lol lol im bolting the box to my wall i have a ext sonoma and want maximum bang with minimum room thats why i thought slanted mercury milan 1x SA-15 1x db Drive 1000.1d 1x db Drive 80.4 nexus 7 in dash fosgate in doors and deck Id imagine youd get alot of help if you posted in the right section Link to comment Share on other sites More sharing options...
Slammin sonoma Posted April 8, 2013 Author Report Share Posted April 8, 2013 double baffle means the layer the subs are sitting on correct? mercury milan 1x SA-15 1x db Drive 1000.1d 1x db Drive 80.4 nexus 7 in dash fosgate in doors and deck Id imagine youd get alot of help if you posted in the right section Link to comment Share on other sites More sharing options...
BassJunkie Posted April 8, 2013 Report Share Posted April 8, 2013 Yes that would be correct. Just double layer where the subs are mounted (baffle) and brace if needed 1986 C20 Suburban 9 American Bass XFL 15's B2 M1MKII 14v XS Power Batteries Maxwell Caps Acoustical energy is free. Electrical energy is not you havent lived until you've hit a screw with a router. Link to comment Share on other sites More sharing options...
Pioneerchuck Posted April 8, 2013 Report Share Posted April 8, 2013 Oh ok you can do a nice build in that truck, I assume your ext. cab is that 3rd door kinda thing? If so you got plenty of room where you don't need to do a slanted box. There are a couple guys I've seen on here who have done some crazy installs in those trucks without doing a blow through. As for bracing, all you'll need is a threaded metal rod 4 washers and 4 bolts. Then cut the rod to fit in between the top and bottom of the box then bolt it down so it doesn't move. Link to comment Share on other sites More sharing options...
