RE MT and AA Mayhem
CJSmith
This isn't a vs thread. I've been looking around and found a set of RE MT 18's that are blown for $350 for the pair. The MT's and Mayhem's look identical cosmetically. My question is, I have 2 Mayhem 18's. Can I buy the MT's and recone them with Mayhem recones and run them together? Thanks for the help. :drinks:
*Rebuid in progress*
The RE MTs are more of a SPL sub where the Mayhems are More of a daily ground pounding sub.RE MT and Mayhem motors are VERY similar same size even BUT the MT has a tighter voice coil gap and mayhems runs a wider gap plus mayhem has cooling etc...think older Fi BTL fully loaded Triple stack motor ..i wouldn't do it..
2000 Suburban 6 runs of 2/0
12 JBL Pro audo mids ,6 timpano audio tweets and 1 Prv compression horn per door
475ah of yin long LTOs
Triple 370 Amp Autotech Alts
mids amps 2  Crescendo Skyway 3ks
compreesion horn amp crossfire 800.4
Tweet amp Crossfire 2000.4
sub amp: 4 Crossfire XT 8ks
Subs: 8 18 in Crossfires in a 4th order
Best Scores at events…
163.5@38hz DBdrag  sealed on the dash… 164.3 outlaw…162.9 Meca headrest
I appreciate it, thanks for the help. Like I said, they looked very similar so I just didn't know if it was possible.
not possible the MT was never designed to play music. it was just found that they did it and sound pretty good. they have a very tight gap.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I think re Mt's have a 4 inch voice coil right or wrong and the mayhems have 3 inch coil
Nope, both 3"
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
The old BTL is commonly known as the 'UFO' version due to it's flying saucer looking single mag...
I can also confirm that they are both 3" and that they (MT) were designed to be an SPL sub but was later found that they play music with some serious authority.
The motors visually at least are identical. Neither has a pole piece either...
I have an MT motor right here, if someone has a Mayhem motor, will you take some measurements?
No, the old version was a triple stack like the MT. It got replaced with the UFO style motor
No pole piece? Is that even possible in a sub? Lol
Unless I'm thinking about something else
Team Flex Issues
You're totally right, I forgot about that one :)
Pole piece... You know; pole vent... that 'hole' thing that acts as a vent
  • Who's Online   0 Members, 0 Anonymous, 466 Guests (See full list)
