I'm looking to upgrade amps in the future from 2 1500.1'ds to 2 2500.1'ds. What they will be powering is two 15" ZVX's. My question is that can I power them at .5 ohms or would I be better at 1 ohm? I have 2 batteries in the rear already that's powering the 2 1500.1D's, do I need to upgrade batteries or add more? I'm also getting a Singer 250A alt from him would that be sufficient or should I ask him for an upgraded unit? Whats the max clean RMS power that that ZVX's can take? Can one ZVX handle 1 2500 at .5 ohms or should I just to 1 ohm?
Skar Audio SDR 10" x2 (Sealed Box)
Skar Audio 1500.1D (1 Ohm) x1
Skar Audio TX525c (Front with dash tweeter) x1
Kenwood Excelon KFC-X173 (Rear Coax) x1
JL Audio 360.4 (Mids & Highs Amp) x1
DEH80-PRS
XS Power d3400
Singer Alternator 275A
98 Jeep TJ 4.0 5 Speed
I would wire to 1ohm, I don't think skar warranties there Amps @ 0.5ohms so why risk it. 1 zvx on each 2500 @ 1ohm would b plenty for that sub. Just make sure u have a clean signal an all.
My build
98 s10 2.2
3 american bass HD 15s with psi soft parts. (on there way here)
atomic at-3000.1 (soon) 146.2 outlaw @39hz., bad alt an bad batt when termed (old 2 12" build)
alpine 6.5s in doors
infinty 4x6s in dash.
clarion cz201 HU.
mechman 240a H/O alt
stuff i still need.
SHCA 2/0 wire
SHCA 1/0 to 2/0 adapters
Atomic AT-3000.1
Lots of sound deadner
new mids an highs, still debating on what to do.
A few Deka g31 batts.
Okay, I'll keep it to 1 ohm. I don't want to void the warranty if I go below.
DEH80-PRS
XS Power d3400
Umm, do you have the subs already? If not, then get two dual 2 ohm subs, wire them to 2 ohms, then strap the two amps...or one amp per sub at 1 ohm...
You can't do .5 or 1 ohm in the same sentence (if you have the subs already) ---if that makes sense?
10501650_10203332501847103_1859383749711
Blown
Yup, I have had the ZVX's in for about a month now. They are 2 ohm. My mistake your right. I messed up I thought that I could wire them down to .5 ohms. But now that I know that I can't I think that I will do 1 sub per amp at 1 ohm. Sorry for my mistake. But on a side note the ZVX's can handle 1 2500 per sub at max clean power if set by my DD-1 for extended periods of time? Or can they handle more power? I'm looking to get as much power to them as possible with it being clean and not going to destroy the subs. Which leads me to one of my questions, How much power can a single ZVX take?
DEH80-PRS
XS Power d3400
I have 4 D1 ZVXv2 15's on 2 2500.1's strapped at 2 ohm just like the manual says so 2 15's on a 2500 would do fine or a 2500 on each just make sure you have good electrical...
William - Metter,Ga. Dad, Self Installer/Fabricator & Repair Tech, Weightlifter, Motivator,
Team SKAR Audio Captain, Team Deadly Hertz Georgia Leader
99 Toyota 4Runner SR5, "Rolling Thunder"
Daily Driven, No Wall, C-Pillar Build, BASS LIFE!
2K16 SBN MECA Park and Pound DB3 Champion
2K16 SBN ISPLL Real SPL Class F Champion
Second Skin Damplifier Pro, Kenwood eXcelon KDC X498, Clarion EQ, Knukonceptz RCA's
The Big 3, Sky High Car Audio OFC & Kicker Hyperflex Silver Tinned 1/0 Gauge
Singer 340a Alt, Northstar NSB-AGM31, SMSAGM480, 12 NessCaps Super Caps
Rockford Fosgate 3Sixty Line Driver, The Oval Port Tuned To 31 Hz, CNC Machined
4 SKAR ZVXv2 D2 15's, 2 SKAR SK-4500.1's, 4 SKAR PAX 6.5's, 2 SKAR LP-80.4's
MEMBER OF THE YEAR 2013
If you don't have any haters, get some, best motivation there is...
What Will said. They can handle 2500 on each with clean power and the right electrical, but honestly, IMO, I would strap them to 2 ohm. 2500s are strapable and when straping, the impedance load is 2 ohm and two dual 2 ohm subs will be 2 ohm. That's my opinion though. Same wattage as running one amp to one sub at 1 ohm. :)
Blown
I read somewhere here that if you strap you lose output is this true?
DEH80-PRS
XS Power d3400
Never heard that. Actually heard the opposite. Strapping some times does more power. I could very well be wrong, but I believe there is a 'strapping' module in these amps allowing for them to be strapped and balanced 'equally'. Or something like that lol
Blown
  • Who's Online   0 Members, 0 Anonymous, 1837 Guests (See full list)
