Two Different voltages... We have a problem
Now I think this fuse went out... It was charging back up fine and then it started staying at 13.6 again I'll have to double check after class
It's a 250 amp fuse... I think its because the wire is so torn up though is what is causing it to fail... Idk though. Also its a power kit so it came crimped from IXOS
How much equipment do you have running from that fuse? Regarding what you said about the wire getting torn up: I'm starting to get concerned you might have a short somewhere. It's possible that the insulation on the wire may have rubbed through somewhere and now it's grounding out
I have a skar 2500.1 on it and the gains are set with the dd1... But I can only turn my head unit 3/4 of the way up right now because of voltage drop as I am saving for a battery bank..
Run new wire. If you got cuts in the insulation, there is a good chance it is grounding out somewhere. Can you visually inspect the entire wire?
I can't visually inspect all of it but I will probably just pull I out tomorrow before it damages the amp. Thanks man I will probably just buy some 1/0 welding wire or car audio power wire soon, ofc of course
  • Who's Online   0 Members, 0 Anonymous, 1117 Guests (See full list)
