Fusing above 300a
In a perfect world, you can see that and some. Daily systems aren't perfect, no matter what you spend on them. The amp can draw that and maybe you you can build an electrical system to supply it. A lot goes on between A and B. If you are really concerned about it not holding up to the current, then get a distro block that holds 2 fuses. Run a pair of 200's and call it a day. The fuse is only there to save the car from catching fire.
Yeah, I understand that now.
Sorry for dragging that on boys.
Avalanche
Alpine Type S comps
Alpine Type S 10''
Alpine MPR-F300
Alpine MRX-M50
Mechamn 270
XS Power d3400s
Run it unfused! At your own risk of course =]
04 dodge dakota ext cab 4x4
excessive amperage 300 amp alt with MONSTER stud =)sundown z v3 15 in a 4th order on aq2200sundown 100.4 2 way active...2 Prv audio 6mb200 & 2 re XXX tweetersdeka intimidatorkenwood x396big 3 1/0 knu wire back to deka intimidator
Just run a 300. By the time you figure voltage drop and box rise, your amp wont pull 300a of current
This is true, but my plan is to run dual 300a alts with 4 or 5 batteries...Id like to think that the amplifier will draw close to the rating.
Lol if that is your plan for you car, and your complaining now about $17 for a 350a fuse. Just wait until you want to run all of what you just stated. You're easily looking at 2-3 grand just in those alts and batteries, and possibly another couple hundered ontop of that 2-3k for all the wiring needed to have a healthy flow of electricity throughout the car.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
To everyone that thinks doubling up fuses is the solution, I really don't think that works. To double up fuses means you have to divide the current between the two runs going to the amplifier. I'm pretty sure that electricity takes the shortest quickest route, and you cant just direct it to "split" into two fuses. If you have two different power sources maybe but coming off a buss bar as a single source I'm really really sure that wont work.
I need Tony C here.
Power takes the path of least resistance meaning that the load will spread across the two fuses as resistance on each builds. 2 150's on a run is the same as 1 300. That's why you see some inline fuse blocks with 2 or 4 mini-anl fuses. The problem comes in if you try to run 1 300 and 1 50, that won't work as it will try spreading the load evenly and pop the 50.
As King said a 300 is fine, but just wanted to help with the confusion. ;)
If at first you do not succeed, you are doing it wrong! -ARS
Check out my walled TBSS build over here
4 Fi Team 18s on 2 Cactus K9
DS18 doors on 2 MBQ 1Ks, Vifa pillars on a STL4.500
Pioneer X8500
6 XS Power D7500, 1 3400S
Second Skin
2 270a Mechman Alts
that fuse holder runs 3 in parallel so you have the option to fuse for 360a (3x120) rather than 400a (2x200) if that makes a difference to you
06 pontiac grand prix
alpine ida x100
rf t2 comps
rf t1500, t400-2
knu 0
big 3
xs d3400
oct 11 tentatively: 2 obsidian 18 v2's
I need Tony C here.
I also forgot to talk about that, yes OP you can run multiple fuses to achieve certain fuse ratings you may not be able to get from a single fuse. But they all must be exactly the same fuse rating if using multiple.
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
Pioneer AVHX-5800BHS
Alt CES 200/270+
  • Who's Online   0 Members, 0 Anonymous, 947 Guests (See full list)
