What kind of amp to power 2 SA-12's
Stephen Dunnington
I have the sq1200d and it would be the best amp to start with if you dont have any electrical upgrades and the correct equipment to set up a larger amp properly.
edit: just saw your list and will say the sq1200 will be your best bet.
[sharedmedia=garage:vehicles:2223]
CAFForumSig_zps376518ed.jpg?t=1364077982
SD, thank for the input. I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
I paid 269 for mine. Amp kit cost 40. So total of 309. His budget was 300-350 right?
The SQ1200 is a great amp, but you'll gain the most when you build a proper box for those SA's.
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
Any idea on how I can calcuate the perfect box? I can't go much bigger than what I already have. About an extra 3 inches in width, 5 inches in height, and plenty of length. Should I just build a box that is larger in length? This would also be my first box build
Here is the amp: http://www.soundqubed.com/Q1-1200D-Amplifier_p_30.html just buy it directly from them will be your best option.
if you can post up the MAX dimensions you have, I or someone else on here can design you a box that will work the best. Some guys will charge you, some won't. I dont charge and I know for a fact JoeX does not either.
Any idea on how I can calculate the perfect box? I can't go much bigger than what I already have. About an extra 3 inches in width, 5 inches in height, and plenty of length. Should I just build a box that is larger in length? This would also be my first box build
Post a thread in the subwoofer/enclosure section. Make sure you have max dimensions, what you want it tuned too/what music you play, and what amp you are going to pick for it with the wiring option picked. Such as 0.5-ohm (not advised without strong electrical, because damage caused by this isn't covered by most warrenties), 1-ohm, or 2-ohm.
Krakin's Home Dipole Project
  • Who's Online   1 Member, 0 Anonymous, 1163 Guests (See full list)
