More info on the output meter? What exactly is its purpose? (noob question lol)
Love how the all turn on :)
It is similar to another product we have, the VU-DIN. It gets connected to your amplifier output (speaker terminal). Once properly calibrated, it works like an indicator of how close to maximum output your amplifier is. Like a tachometer for your engine, this lets you know when your amplifier is "hitting the redline". You can use multiple units, put one on each speaker output and monitor your entire system.
on the tm-2 can it be use to see the temp of the back of a wall where amp will be at
TM-1 and TM-2 come with a small electronic sensor on a 18 foot long tether. The small sensor is made to be glued to any surface you would like to monitor the temperature of, or just left in mid-air to measure air temp. All you need is some cyanoacrylate glue and your are good to go.
  • Like (+1 Rep) 6
Dope products u guys keep droppin....nice work fella's!
if you put a DD-1 in your amp terminal and it immediately went up in smoke, i would be concerned.
If you shoved your dick in the terminal and it didn't blow up but a month later it blew up, i STILL WOULDN'T be able to blame your dick.
It just does not make sense at all.
Is the output meter the same and as the WM-1?
Build Under Construction
Head Unit = Kenwood DDX514
Amps = Kicker 750.1, Going to install Sundown 1500D v3 and Sundown 125.4
Battery = XS D3400
Wires = Kicker RCA's, 0 Gauge street wire and Stinger
Mids and Highs = Stock
Sub= Kicker L7 12"
Alternator = 220 Mechman
Sound Deadner= Fatmat and Stinger Road Kill
like the om-1 thats bad ass!
*** SuperSeller Status Verified *** ( http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers/ )
"kevosinn's" astro van
8 custom Sundown Zv4 18's
4 Sundown scv 6000's
CNF Distribution CNC parts
Skyhigh wire
some batteries
SMD Meters and tools used on the install
http://www.stevemeadedesigns.com/board/topic/172877-kevosinns-vanwest-coast-skyhigh-car-audio-vehicle/
16,000 watt walled silverado build.
http://www.stevemeadedesigns.com/board/topic/161965-walled-silverado-4-hdc4-15s-4-crescendo-3500s-and-much-more/
8,000 watt 1999 Subaru legacy outback. Build log here: http://www.stevemead...ru/page__st__60
TEAM CNF Distribution
thats cool so when u accidentally blow a speaker or so this will let u know.
im needing a few gauges for my truck. can these be used instead of the stock ones?
i will only need a fuel gauge. oil pressure to go with the vm-1 am tm-1
this would be seriously cool and i will def get
REFF'S
My link
EBAY
http://feedback.ebay...ck&myworld=true
I love car audio so much because I will never be done. I can never win, and I will never get it finished or perfect. It always has me coming back for more, I can never get my fill of it, but I get what I need.
