soundstream15 Posted May 3, 2013 Report Posted May 3, 2013 I'm running 2200rms. I have voltage drop and that, I'm running kitneik hc1200 in the rear but heard if I upgrade that, it's not gonna make a difference. I know that amp can put out more power so would an alt be good? Where can I get a cheap one? Like around 300?
cjvue Posted May 3, 2013 Report Posted May 3, 2013 What's voltage drops are you experiencing? And what final ohm load you're running? My Build Log- T E A M S U N D O W N A U D I O - 2013 DbDrag WF SS1-2 - 5th Place 154.6db 2013 MECA Mod3 CA State Final Champ 153.4db Powered by: Sundown Audio
TylerParrish Posted May 3, 2013 Report Posted May 3, 2013 Battery reserve can only help you electrical but so much if your alt can't put out enough amps to keep a steady voltage. Bigger batterie(s) will help, but they're only band-aids. Invest in a new alt if you really want the most out of that amp. What the f**k is an appropriate signature supposed to look like?2013 Kia Forte Koup Pioneer AVH-X4600BT iDMax 12 DD M1c @ 2 ohms Rockford Prime 200.2 Pioneer 6.75" Comp Set XS S3400, D2700 Project DB Battery Terminals Axxess ASWC Stinger HPM Everywhereeee 90 Sq. Ft. of Stinger Roadkill Stock Alt Stuff To Come Sundown X-12 New Amp New Comps 4 Channel Amp My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/ My Old Build: http://www.stevemead..._+2000 +mustang Avatar Courtesy of SnowDrifter
Tarball Posted May 3, 2013 Report Posted May 3, 2013 Battery reserve can only help you electrical but so much if your alt can't put out enough amps to keep a steady voltage. Bigger batterie(s) will help, but they're only band-aids. Invest in a new alt if you really want the most out of that amp. Quality Alt is key - new garbage is still garbage CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db
Swordlordboy1234 Posted May 3, 2013 Report Posted May 3, 2013 New ALT all day bro. I had3 batteries on my stock alt on a 2500 and I dropped 10.4 after a couple bass notes. Basically if you get an alt your still gonna drop 12's till you get a battery.. But if you get a bigger battery your gonna drop 11's till you get the alt. My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect?
TylerParrish Posted May 3, 2013 Report Posted May 3, 2013 Battery reserve can only help you electrical but so much if your alt can't put out enough amps to keep a steady voltage. Bigger batterie(s) will help, but they're only band-aids. Invest in a new alt if you really want the most out of that amp. Quality Alt is key - new garbage is still garbage True...ebay alts are still a big no no. There's a reason they're cheap. What the f**k is an appropriate signature supposed to look like?2013 Kia Forte Koup Pioneer AVH-X4600BT iDMax 12 DD M1c @ 2 ohms Rockford Prime 200.2 Pioneer 6.75" Comp Set XS S3400, D2700 Project DB Battery Terminals Axxess ASWC Stinger HPM Everywhereeee 90 Sq. Ft. of Stinger Roadkill Stock Alt Stuff To Come Sundown X-12 New Amp New Comps 4 Channel Amp My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/ My Old Build: http://www.stevemead..._+2000 +mustang Avatar Courtesy of SnowDrifter
soundstream15 Posted May 3, 2013 Author Report Posted May 3, 2013 200amps is the fusing for that AQ2200. I am at 1ohm. I'm in low 13s but when the bass gets lower the volts drop lower lol lowest I seem was 11.9 on 27hz. Usher-daddy's home. Seems I have no rise on those damn low notes lol
cjvue Posted May 3, 2013 Report Posted May 3, 2013 Sounds like you're all stock eletrical (minus the 1200). Ideally, I would upgrade the alt since you already have the 1200 in the rear. Don't cheap out on alt, it's the heart of your audio system... it pumps blood to multiple sources in your car and keeps your system (including your car) going on a daily basis. My Build Log- T E A M S U N D O W N A U D I O - 2013 DbDrag WF SS1-2 - 5th Place 154.6db 2013 MECA Mod3 CA State Final Champ 153.4db Powered by: Sundown Audio
