Yes MUCH better, louder, and lower than the JBL IN THE RIGHT BOX AND ON RIGHT POWER. , i would never touch a Jbl product in my life (no offense) but thats along with kicker, sony, pioneer....
With that being said, idk what your battery size is but i would do a run of 0 gauge to the back and put maybe a XS D1200 or bigger in the back. Get on your local craigslist and look for deka's or XS. I like dekas and you can get them for cheap!
2007 Volvo S40 2.4i (no turbo :( )(Soon XS Power D2400) Stock battery for nowRockford Fosgate 4 gaugeAudioque 6.5" Mid Bass (front)Rockford Fosgate T1 Tweets (front)Rockford Fosgate T2 6.5" Mids (rear)Rockford Fosgats T600-4 (Mids and highs)Rockford Fosgate P3001Fi SSD 12" with PSI recone, building box<p>400 watts, 139.3 @ 42 hz , in the kick window open. Build log!!http://www.stevemeadedesigns.com/board/topic/159148-2007-volvo-s40-audio-build-start-to-current-comment/
Sorry for the dumb question but if i understood correctly ill need a battery on my trunk to power the system or can i just replace the one in front? or do i need to replace the front and add one more to the trunk?
ALL options except high QTS ( unless your planning on runnin sealed)
Ill be running Sealed for a crispier and better sound (i was told). Ill choose 1ohm right?
also on the battery subject can i just replace my stock battery with the XS Power D1200 and be good?
so since i need my trunk space i design a box and amp installation to save on space here is my first 3D drawing ever! (is draw to the perfect detentions and to a 1.5 cube size for the sub)
top and front
sides
**note how the amps and sub will sit flush with the outer face of the box
I well designed ported box will be louder, lower and still sound just as good as a sealed box. I've seen SQ ported boxes tuned super low, like 28hz in some cases. Nice choice of sub with the FI Q. ;)
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
cool thanks for the input, however, im extremly tight on space as is and that why i opted for a sealed box and was forced to tilt the amps as shown on the pics.
**Edit - I found this post on here (http://www.stevemeadedesigns.com/board/topic/149340-enclosure-for-single-fi-q-12/) where he did a ported sub box for the Fi Q12 i could use this and mount the amps to each side of the box, my question is if i do this would it mess the integrity of the box or anything. by doing this ill have 1.36" of air from the amp to the side wall of the trunk on each side. if i was to double up on the MDF on each side of the box to make it more regid when mounting the amps ill only have .61" ( a little over 1/2 inch) on of air what should i do??
  • Who's Online   0 Members, 0 Anonymous, 584 Guests (See full list)
