chad190 Posted May 3, 2013 Report Share Posted May 3, 2013 Would a 90 amp stock alt + YellowTop Optima Battery under the hood + BlueTop Optima Battery in the back with all the wiring being @ 1/0 support this amp? 2006 Monte Carlo Pioneer DEH-80PRS 2 SSA ZCON 12's 5 Cube Box tuned to 32 Hz Soundqubed 3500.1 PAC LC-1 Singer 320 Amp Alt XS D3100 & Kinetik HC2400 in trunk Super Start AGM Under Hood 80ft+ Sky High 1/0 40 ft^3 120mil sky high deadener Soundqubed Pro Audio 6.5" mids Soundqubed Super Tweeters Alpine 1" Tweeters Alpine MRP-F300 Link to comment Share on other sites More sharing options...
pdx94z28 Posted May 3, 2013 Report Share Posted May 3, 2013 I think you could get by maybe. I was getting a lot of voltage drop in my Camaro running that amp at full tilt. my setup is in my sig. 1994 Camaro Z28 Skar ZVX 18D2 5.0cuft box 8" port tuned to 36h AQ2200 on the Skar PG V754 on the doors kenwoods for now All knukonceptz 1/0 power and ground Duralast platinum H8 battery in the back stock 140 amp alt for now YouTube is pdx94z28 Link to comment Share on other sites More sharing options...
boom50cal Posted May 3, 2013 Report Share Posted May 3, 2013 I'm gonna say that would be cutting it close. Maybe throw in another blue or yellow top, double up your 1/0 big 3, and do another run of 1/0 to the rear. Still, you'd have to watch your voltage at the amp like a hawk. On 1/4/2013 at 9:31 PM, HatersGonnaHate said: Wow. 184 posts and I think you're a fucking asshole. Link to comment Share on other sites More sharing options...
RooTxBeeR Posted May 3, 2013 Report Share Posted May 3, 2013 Even with a big reserve, your cutting it very close. If you do go ahead with it, keep a very close eye on your voltage, once you deplete the batteries your alt won't stand a chance. On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5 Link to comment Share on other sites More sharing options...
soundstream15 Posted May 3, 2013 Report Share Posted May 3, 2013 That electrical is not gonna work. I have big 3, optima yellow top under the hood, stock alt and kitneik hc1200 and 1/0awg. Dropping in high 12s Do the big 3 and replace that blue top. Make sure you got a volt meter to watch your volts Link to comment Share on other sites More sharing options...
chad190 Posted May 3, 2013 Author Report Share Posted May 3, 2013 Okay, what battery should I run then? It's going on 2 OA 18s. You think I'd be better off going with the 1200 instead? 2006 Monte Carlo Pioneer DEH-80PRS 2 SSA ZCON 12's 5 Cube Box tuned to 32 Hz Soundqubed 3500.1 PAC LC-1 Singer 320 Amp Alt XS D3100 & Kinetik HC2400 in trunk Super Start AGM Under Hood 80ft+ Sky High 1/0 40 ft^3 120mil sky high deadener Soundqubed Pro Audio 6.5" mids Soundqubed Super Tweeters Alpine 1" Tweeters Alpine MRP-F300 Link to comment Share on other sites More sharing options...
Kranny Posted May 3, 2013 Report Share Posted May 3, 2013 new alternator, not battery. you're still going to have voltage drop with 10 batteries. need more power created, not stored. if you want to be able to play for long periods of time without having to worry about voltage, get a new alternator. Link to comment Share on other sites More sharing options...
pdx94z28 Posted May 3, 2013 Report Share Posted May 3, 2013 A alternator before anything else. I went so far as to pull all fuses on my t2500bdcp until I get my alternator in. I was dropping to 12.2-11.8. Hopefully it won't be to long before I get the alt. I would rather not risk messing up expensive equipment because of low voltage. 1994 Camaro Z28 Skar ZVX 18D2 5.0cuft box 8" port tuned to 36h AQ2200 on the Skar PG V754 on the doors kenwoods for now All knukonceptz 1/0 power and ground Duralast platinum H8 battery in the back stock 140 amp alt for now YouTube is pdx94z28 Link to comment Share on other sites More sharing options...
boom50cal Posted May 4, 2013 Report Share Posted May 4, 2013 Mechman is having a sale on truck alts now, if you have a truck or SUV. Like $341 for most. On 1/4/2013 at 9:31 PM, HatersGonnaHate said: Wow. 184 posts and I think you're a fucking asshole. Link to comment Share on other sites More sharing options...
chad190 Posted May 4, 2013 Author Report Share Posted May 4, 2013 Alright, new alt it is! Thanks guys 2006 Monte Carlo Pioneer DEH-80PRS 2 SSA ZCON 12's 5 Cube Box tuned to 32 Hz Soundqubed 3500.1 PAC LC-1 Singer 320 Amp Alt XS D3100 & Kinetik HC2400 in trunk Super Start AGM Under Hood 80ft+ Sky High 1/0 40 ft^3 120mil sky high deadener Soundqubed Pro Audio 6.5" mids Soundqubed Super Tweeters Alpine 1" Tweeters Alpine MRP-F300 Link to comment Share on other sites More sharing options...
