Krakin's Single Cab '03 Sierra
That design looks hott man..... wish I knew how to use sketchup .... awesome!!!
Thanks for the advice. But how far is the recommended distance for loading off a 4 inch port?
Changed my design a bit so I don't have port sticking over the amp rack, so that I can position my amps how I want.
Pioneer Premier P880PRS ll Front Stage: US Acoustics 4060 - Random speakers currently ll Sub Stage: Crescendo BC3500D - 15" Xcon sealed @ 3.28 cubes ll Electrical: - Kinetik HC1800(front) NEW***DieHard P-2(rear)
beaker- I know this sounds like a lot of anime bullshit, but it is true.
I'm thinking of changing the port back around to load off the driver B-Pillar, 3 inches from where port would end. Or I can shorten the external part and just increase the internal port. Might do that since I am considering upgrading amps in the future to a 1k and need to get the volume down.
Krakin's Home Dipole Project
http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370
Krakin, are you some sort of mad scientist?
I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
What you hear is not the air pressure variation in itself
but what has drawn your attention
in the two streams of superimposed air pressure variations at your eardrums
An acoustic event has dimensions of Time, Tone, Loudness and Space
Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears,
thus no formula can achieve a definite effect for every listener.
im just asking but wouldnt make more of a diff if the sub was on the other side of box instead of being below the port the way you have it?
I really have no clue for that. I was thinking it would cause internal pressure problems. But in the reply posted above I plan on making the port reverse exiting the box from where it currently shows the exit and making it exit out the external portion. I hate all those bends but only way I could think of with out aeroports sticking out all over the place.
So got the port how I like it now. No more working with aeros! Even though I have 10' of 3", 24" of 4", and two 90o 4" angles..
But to change tuning or to get farther/closer to loading wall is pretty easy now.
I'll take some of that 3" if you'll be so kind to drive it over here :)
Sure $80 or more in gas for $10 in pipe lol.
What do you get on the highway?!?! I get like 22-24, 3.08 gears kick ass. Cruising 70-80 from 2k rpm to 2100 rpm. Lay into and I can pass for days lol.
hang on lemme google map this.
