head gasket or piston rings
Thanks for the replys guys. I'll check the pcv valve and compression test.
The build up im not sure about, i want to say valve cover but im not to sure
Alpine 9884
RF T2 comp set up front
The Epicenter
2x RF T10001bd
2x Sundown sa-15 t-line
Big 3
Smd DD-1
head gasket eh? explain to me why that oil is on the valve cover around where the valve cover gasket meets the head, not the head gasket.
Thats caused by oil seepage and dirt collecting.
Combustion gas fluid test or a 4 gas analyzer would be the way to test that for a head gasket issue in the radiator neck to test for combustion gasses in the cooling system.
As for the plug, being that isnt a shiny looking black and more of a flat black, i am going to say that cylinder is running rich as hell. If it was a shinny black, it would be a severe oil burning issue.
the spark plug had oil on it i cleaned it off with my finger, the car isn't popping codes she just had emission at the end of last month
Alpine 9884
The Epicenter
2x RF T10001bd
Big 3
Smd DD-1
Ok guys pcv valve is good, all the other plugs are good and i did notice that the air filter is some what dirty and that the exhaust smells like gasoline, I'm thinking it's from the bad spark plug
Alpine 9884
The Epicenter
2x RF T10001bd
Big 3
Smd DD-1
its going to smell like gas from it running rich from the fouled spark plug. only problem with running a compression test is that if the oil ring on the piston is bad, the compression test wont show that.
to me, that is what it seems like. the oil ring is/has gone bad.
only thing I can think of is to run a one step hotter spark plug and see how it reacts to it. probable wouldn't hurt to run some sea foam through the system and clean everything out.
My build log http://www.stevemeadedesigns.com/board/topic/143943-2001-mustang-gt-system-rebuild-box-build-pics-updated-61512/
2001 Ford Mustang GT
4.6 SOHC 380HP
270 amp Mechman alt
2 12" Treo SSX custom built.
6.47 cu ft, tuned to 32Hz
2 hifonics Brutus 2400.1, strapped
1 optima yellow top
1 Kinetic HC1800
14.4v @ 29Hz, 2k RPM
over 100ft 1/0 XS flex wire
Big 3 in 1/0
100sq ft fatmat deadener
145.3 on music, 142.6 sealed on music
Stop being a pussy and wall it off.
I hate when my google breaks too
I think the usps must be ran by a bunch of drunk ass oriental midget monkey's on methamphetamines.
Deff the head gasket bro I'm a tech and I know for a fact its a head gasket
or the plugs are just old as fuck.
2015 Honda Civic LX 4dr | 24k miles
Stock H/U and mids/highs
Power Acoustik GW3-12" D2 Sub
HiFonics BXX1200.1D @ 1ohm
Random 2.5^3' dual ported box
NVX LOC
Stinger wiring throughout
1977 Chevy SWB
Cammed 350
Dual exhaust
Cheap Wish stereo
My car had a bad head gasket and the plugs were normal....
if your talking about your subaru, there's a reason for that...... they dont blow headgaskets the same way as other cars in most instances.... coolant doesnt actually get into the cylinder..... exhaust gasses pass into the coolant because the gasket deteriorates in a certain spot almost every time...... did the put the new updated MLS gaskets in? Hope so :)
i think there real i was looking through that guys stuff he sells and it looks like he finds stuff at auctions and just sells it
Yea, it looks like someone got the mids about a month ago....shit. If I had a whole Hertz front stage my ears would jizz all over my cheeks.
/ LOL
My Low Budget Build:
Green 1995 Subaru Legacy wagon 147k- $1K
headunit- pioneer premier deh-p650-$25
4 Lead acid batts. 1 up front and 3 in back- vented outside.- $50
4 vvme L11 10"s <- $30 shipped a piece
6 cu. ft box (after displacment) tuned to 32ish hz with 10 inch sonotube. -about $50 all together maybe a lil more
2 aspm 1300 strapped
Selenium 6"s in the front doors on headunit power- for now -$20
quantum tweets in door-for now -$10
boston acoustic 5 1/4 in rear doors- for now-Free
big 3
1/0 and 4awg throughout.
roof sound deadened (not peel n seal ftw)-free
on 80 amp alt (bench tested to put out 100 amps faithfully) <--?-$10 for test
about $430 for everything<----Not bad at all
still gotta add 3 way crossover, amp for front and rear door speakers and maybe eq
best bet would be a leakdown test. that way you can actually hear where the leak is. could be bad rings, or valve guide seals. as far as the leak on top, clean it off really good, and just run it to see where the leak is coming from.
  • Who's Online   1 Member, 0 Anonymous, 1316 Guests (See full list)
