SnowDrifter Posted May 16, 2013 Report Share Posted May 16, 2013 To be honest its a waste to wire that low on that small of a amp, Any increase in the 300-600 watt range you won't hear a audible difference. This, and that.... yes, and yep....with a yup in there. Truly, unless your a tenth away, from a wanted goal... you wont even notice bro, and, youll just have negatives (pro and con wise) doing so. Just get a bigger amp if your looking for a bigger increase. Sorry to burst any bubbles... Those amps run pretty warm at 1 ohm anyway. Running at .5 they would get HOT HOT HOT ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
Watch the bass Posted May 16, 2013 Report Share Posted May 16, 2013 The classical answer is "if you have to ask" to this theme. By the way don´t burn your BRZ amp, there sold out only a vew new are on the market. You can get a good money of them, BRZ line is well known. "in the abundance of water, the fool is thirsty" Bob Marley Link to comment Share on other sites More sharing options...
Omega5002 Posted May 16, 2013 Report Share Posted May 16, 2013 I say just get a bigger amp and run it at 1 ohm instead 2003 Kia Sorento Team Subsonic LowsTeam Bassin' on a Budget2016 Rebuild Under Construction Best score: 150.2 at 40hz (3k, 2 Custom HDC3 15's) Usaci style(door open, in the kick) Link to comment Share on other sites More sharing options...
thefourth Posted May 16, 2013 Author Report Share Posted May 16, 2013 i wasn't looking to gain from it. Just wanted to get some info on weather or not it could be done in a somewhat safe manner. However, if there's more cons than anything I'm going to hold off. Thanks for the responses fellas cheers! Thanks alaskanzx5 I might just do thatI can recone a sub myself. About a year ago I took 2 12" power acoustic mofos and made one sub. I took the magnet and the motor off of one and j b welded it to the other motor and magnet. I had to wind my own voice coil so it would work. After I was done hooked up to 2 boss 5000w amps. And shattered my back and all my side windows came to this thread to recommend soundqubed and ct sounds. OP goes with soundstream. oh lawd. Link to comment Share on other sites More sharing options...
Kyblack76 Posted May 16, 2013 Report Share Posted May 16, 2013 i wasn't looking to gain from it. Just wanted to get some info on weather or not it could be done in a somewhat safe manner. However, if there's more cons than anything I'm going to hold off. Thanks for the responses fellas cheers! Good boy. No harm in asking, and seeing. And, i commend you on your choice. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold Link to comment Share on other sites More sharing options...
Team Maxxsonics John Posted May 16, 2013 Report Share Posted May 16, 2013 The amp is not designed to run at 1-Ohm and I'm sure you are aware. If you want to know how long it will last...there is no certain answer and there are many variables beyond your concern about voltage. It may last years, it may stop working in a day or two. Link to comment Share on other sites More sharing options...
Omega5002 Posted May 16, 2013 Report Share Posted May 16, 2013 The amp is not designed to run at 1-Ohm and I'm sure you are aware. If you want to know how long it will last...there is no certain answer and there are many variables beyond your concern about voltage. It may last years, it may stop working in a day or two. Not designed to run at 1 ohm? Then why you guys rate it at 1 ohm lol 2003 Kia Sorento Team Subsonic LowsTeam Bassin' on a Budget2016 Rebuild Under Construction Best score: 150.2 at 40hz (3k, 2 Custom HDC3 15's) Usaci style(door open, in the kick) Link to comment Share on other sites More sharing options...
95legwagon Posted May 16, 2013 Report Share Posted May 16, 2013 i think there real i was looking through that guys stuff he sells and it looks like he finds stuff at auctions and just sells it Yea, it looks like someone got the mids about a month ago....shit. If I had a whole Hertz front stage my ears would jizz all over my cheeks. / LOL My Low Budget Build: Green 1995 Subaru Legacy wagon 147k- $1K headunit- pioneer premier deh-p650-$25 4 Lead acid batts. 1 up front and 3 in back- vented outside.- $50 4 vvme L11 10"s <- $30 shipped a piece 6 cu. ft box (after displacment) tuned to 32ish hz with 10 inch sonotube. -about $50 all together maybe a lil more 2 aspm 1300 strapped Selenium 6"s in the front doors on headunit power- for now -$20 quantum tweets in door-for now -$10 boston acoustic 5 1/4 in rear doors- for now-Free big 3 1/0 and 4awg throughout. roof sound deadened (not peel n seal ftw)-free on 80 amp alt (bench tested to put out 100 amps faithfully) <--?-$10 for test about $430 for everything<----Not bad at all still gotta add 3 way crossover, amp for front and rear door speakers and maybe eq Link to comment Share on other sites More sharing options...
Kyblack76 Posted May 16, 2013 Report Share Posted May 16, 2013 I feel like John is talking about 1ohm reactive. Not nominal... SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold Link to comment Share on other sites More sharing options...
SnowDrifter Posted May 16, 2013 Report Share Posted May 16, 2013 I feel like John is talking about 1ohm reactive. Not nominal... Then that begs the question: Why design an amp that depends on box rise to keep it safe? Why not rate it at 2 ohms? ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
