Awhitewookie Posted May 21, 2013 Report Posted May 21, 2013 Hello friendlies, I have found this to be one of the easiest ways to wire a car sub and amp in the house http://www.parts-express.com/pe/showdetl.cfm?partnumber=320-315 However, I am stuck as to where I would wire each different component (amp/ sub/ speakers / hu or cable to my computer to play music) I appreciate all help and a drawing or diagram would be awesome! MY BUILD 1998 Ford Explorer 2dr sport 1/0 Big 3 1/0 everything Alpine cda-9884 Crescendo CZ components (2) Crescendo bc2000's (2) Jolt 150ah (2) Yellow top optimas (1) Juicebox black cherry addition (1) Mechman 270 avbm miss my bc5500 and (4) 15's You know why people are ass holes online but not in person? Because getting punched in the mouth hurts.
Bradprobert Posted May 21, 2013 Report Posted May 21, 2013 I would use the 3.5mm audio jack of the computer and use a plug like this to your amp. [sharedmedia=garage:vehicles:2223] 4th-order under rear seat build log: http://www.stevemeadedesigns.com/board/topic/165708-4th-order-under-rear-seat-chevy-extended-cab/#entry2410477 SD, thank for the input. I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
SnowDrifter Posted May 21, 2013 Report Posted May 21, 2013 Want to know the real easiest way? Get equipment that's designed to go in a house. Like a plate amp ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
Bump4life Posted May 21, 2013 Report Posted May 21, 2013 if you dont know how to hook it up, like rca and such you really should just get a plate amp. like there are only so many connections. pretty self explanatory. kinda hard not tomake fun of that question. but RCA to 3.5 MM to a computer or mp3 player. spekaer wire goes to spekaers from amp. amp remote goes into positive on amp. amp positive and negative go to power supply. and thats it Buyer/Seller Feedback Thread: http://www.stevemead...5015-bump4life/ MB C220 153 Trunk Car Build Log: http://www.stevemead...d/#entry1840136 MB C280 Ipad Dash SQ Build Log: http://www.stevemeadedesigns.com/board/topic/194484-bump4lifes-new-benz-tony-c-relay-kit-pictures-ce-electric-audison-front-stage-installed/ My SPL Log: http://www.stevemead...__fromsearch__1 BMW M340 xDrive Stock, for now. Corner Load 10" maybe soon. But does 10s in the 1/4... Best Scores out of a trunk 153.0 sealed legal full tilt clamped 5524 @ 42 hz 154+ windows down, 155+ kick
Bradprobert Posted May 21, 2013 Report Posted May 21, 2013 Lol so true ^^ [sharedmedia=garage:vehicles:2223] 4th-order under rear seat build log: http://www.stevemeadedesigns.com/board/topic/165708-4th-order-under-rear-seat-chevy-extended-cab/#entry2410477 SD, thank for the input. I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
meridianofinsanity Posted May 21, 2013 Report Posted May 21, 2013 I would get two small awg distribution blocks or make your own and hook all positives to one block and all the negatives to another they are all connected internally you wire them together so you don't bottleneck and will keep your voltage higher also make sure to turn the voltage as high as it can go to do the remote just use a wire from positive and put it in the remote and put a switch between to be able to turn it off
Awhitewookie Posted May 21, 2013 Author Report Posted May 21, 2013 Thanks guys. Appreciate it. The reason why I wasn't looking at plate amps is because I have a crunch 1100 laying around MY BUILD 1998 Ford Explorer 2dr sport 1/0 Big 3 1/0 everything Alpine cda-9884 Crescendo CZ components (2) Crescendo bc2000's (2) Jolt 150ah (2) Yellow top optimas (1) Juicebox black cherry addition (1) Mechman 270 avbm miss my bc5500 and (4) 15's You know why people are ass holes online but not in person? Because getting punched in the mouth hurts.
