what mistakes did you guys make when you installed your first system???
1) Gain is volume - more is always better.
2) Nominal impedance loads - EVERYTHING gets wired in parallel.
3) Small wire - Walmart 4 is just as good Knu 0.
And probably the biggest mistake.
4) Not spending the cash on good equipment the first time around..
'11 Jeep Patriot New Build
Head Unit: Pioneer AVH-P3200DVD
Front: Massive CK69 Components
Front Amp: Massive NX2
Rears: Infinity Kappa's
Subs: 8 Sundown SA-8 v2's
Sub Amp: AB 450.1
XS D3100
Come on 150!
in a word - everything
Beginning with no research. Give, we didn't have the internet when I built my first system. Cheap wire, cheap parts, Didn't know what T/S parameters were. Just built the biggest sealed box I could fit, The subs were probably designed for ported and I didnt even know it. Used cheap equipment - pyramid phase III. Used particleboard and not MDF. No Big 3, no upgraded battery, stock alt (maybe 70amp - not sure what was stock on a 78 Sirocco). No sound deadening, Heck, is there anything else i could have done wrong ?
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
Grounding my amp to the fuel pump
Using a prefab
Not having gains set correctly
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
  • Who's Online   0 Members, 0 Anonymous, 1277 Guests (See full list)
