well i got to finish sealing everything up, adjust everything, get a new alt new and different battery's, its not a 150 now, but it will be some day i am happy with it now , but i will always be improving it the best i can
SMDsigbannr4.jpg1995 Geo Prism . FI BTL 12 P chamfer, 3rdmagnet HIXMAX COIL 1/0 big 3 HIFONICS COLOSSUS 1.7 cubs tuned to 60hz in the works 2xTruck battery 1125 cca.
i think in db drag i'll be in ss 1-2nw, because of my battery's, that means they are doing at least a 160 like willy is, o well
just bought an autotek mm3000.1 and threw it on my sxs at a comp in carrollton, ga... 154.4dbs in the kick for first place, loudest truck 13-24in...
Posted Image
i did a 147 in the kick on a term lab as well before the comp...
noobs kthnxbi
The forum upgrade removed my last posting (my account as well...so I had to re-register :)
On my EPIC-150
Posted Image
Here's my system:
'03 Toyota Rav4
1 18" RE MT ( in a 6 cube box tuned to ~33 hz)
1 MA HK4000D
1 extra Costco Batttery
1/0 gauge KNU wiring
I'm going to take out the MA and try out 2 Shredders to see if I can get any louder...
The weird thing is that I've never been able to pop my 200 amp circuit breaker with the MA...the 2 Shredders would pop it occasionally...so I'm wondering how many watts I'm actually putting out...
^ how does the epic compare to a term or a/c? is there a mic you place somewhere?
Lsn2meboom has the real scooby on the EPIC vs. Term but he says the EPIC is about 4 dbs higher then the TL.
BTW, the EPIC is an AC meter. The mic is right about the 150 in EPIC-150 sign (the little hole right above it)
Yea I'm pretty sure a good portion of the informative stuff i put up right b4 the switch got butt-raped into a cyber black hole, but so it goes.
The A/C Epic mics are about 4-5db DOWN from a TL.
One major diff no one ever mentions w/ the TL/Epic comparison is that the EPIC mic is MOUNTED IN THE CENTER OF THE DASH 90%+ of the time.
Thus for a true "FAIR" comparison you'd have to put your TL mic in the same spot the EPIC mic is and we all know how big a difference mic placement can make.
I'M NOT SAYING IT WILL MAKE A HUGE DIFF FOR SURE BUT SOEMTHING TO CONSIDER THAT I'VE NEVER EVEN HERAD MENTION OF IN THIS EPIC VS. TL DEBATE.
The other issue is the Epic mics are NOT adjustable like a traditional A/C mic (AC-160, 180, 190etc) which have a sensitivity "rectifier" to "even the feild" or "adjust" for...variance? I dunno.
I can consistently get nearly 150db outta my Epic-160 (mounted center/under head unit) and I'm around 145db PEAK/burst on a TL (windsheild/dash) and range 140db+AVERAGE/over 2min on music.
COOGLE SAID:"bro thats how we got where we are... buy making messes ...... i still learn all the time you just gota be willing to ruck up some shit" "In order to attain the impossible, one must attempt the absurd." ~ Miguel de Unamuno"One machine can do the work of fifty ordinary men, but no machine can do the work of one extraordinary man" -Elbert Hubbard"A proud man can learn humility...but he will be proud of that too" ~I forget who.I'm far from perfect and I know it better than anyone, but I hope to be good at what I do, when I do it...Installs I've done:My Integra: http://www.stevemeadedesigns.com/board/ind...?showtopic=3161The Lexus : http://www.stevemeadedesigns.com/board/ind...?showtopic=1535Law's Maxima: http://www.stevemeadedesigns.com/board/ind...ic=5568&hl=Jeff's 2500HD: http://www.stevemeadedesigns.com/board/ind...ic=5382&hl=Acura RSX-S: http://www.stevemeadedesigns.com/board/ind...?showtopic=3142Z-32 300zx: http://www.stevemeadedesigns.com/board/ind...?showtopic=34602004 Civic 4dr: http://www.stevemeadedesigns.com/board/ind...?showtopic=8190Trunk/Corner Box: http://www.stevemeadedesigns.com/board/ind...c=16036&hl=1969 Chevy C-10: http://www.stevemeadedesigns.com/board/ind...c=20319&hl=Seat-Back AMP-RACK How-to: http://www.stevemeadedesigns.com/board/ind...ic=9428&hl=Bunch of subs still for salehttp://www.stevemeadedesigns.com/board/ind...l=lsn2meboom916"It's game night...we're playin......sex."~Quagmire"When disneyland started it was powered completely by orphan children running on treadmills to generate e-lectrissty…and today, them children are New York Yankees". ~Dale Gribble"Fill it with ice...then pour it up to the top of the ice...& Shut da Fu** up!" ~Urs truly.
