Fitting Big Subs, Into A Small Car (Dual Fi SP4 18", Golf MK3)
Max1636
So I've got a MK3 Golf which before had a single Fi SP4 18 in a box designed by PWK. I've ordered a second SP4 which I'm planning on fitting in the car. I will be sacrificing two rear seats (the middle and right), but still want to keep the left.
(This ISN'T my car, just a picture from Google Images to give you an idea of what I'm talking about, the seat on the left I want to keep functional,
the middle and right seats will be folded down.)
Continue Reading Below Image...
The dimensions I can fit in that space is 1350x500x500mm or 53x19x19 Inch's (1 dec. pl.). I know this isn't enough, I can increase the height though or make sortof an L shaped box. Anybody got any idea's on how this could work?
(Old Car) 1995 Volkswagon Golf MK3 2.0L:
Fi SP4 18 On A DC Audio 3.5K In A PWK Box
Hertz DSK 6" Speakers, Clarion HU
3x Fullriver 120aH AGM's, 225A Alt
2012 Subaru BRZ:
Audison Prima APK 163
Bit One, Rockford Amps, Audison Sub
Possible band pass but not sure you got enough space
What kind? I've never built a bandpass before but would definitely be willing to do it.
2012 Subaru BRZ:
I Know, I know, the RE Calculator is not entirely accurate. But how does this look? I've never built a box with such a small port. How will it affect the sound?
2012 Subaru BRZ:
Found some more room.
2012 Subaru BRZ:
do a box that will stretch from the front where the seats your taking out goes to the back then do a slot port right behind the seat your leaving in the car as an external port.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
I get what you mean that could work. I would probably have to learn to use a tuning calculator though. Thanks.
2012 Subaru BRZ:
Big subs small car = wall
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
This is exactly what I wanted to do, but I want to be able to see out that back easily. I thought it would be a big inconvenience having it blocked.
2012 Subaru BRZ:
You get used to it to be honest.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
  • Who's Online   1 Member, 0 Anonymous, 627 Guests (See full list)
