fuse holder melted
bassbang89
Hey I'm still new to the whole system thing and I was looking under the hood today and noticed that my fuse holder was starting to melt. And now my amp is not getting any power...any ideas of why it melted and also can that cause me not to get Amy power?
BASS_BANG
Is the gauge wire appropriate for the amperage draw?
Is the fuse blown?
Is the fuse holder cheap plastic that may gave melted with the engine bay heat?
Rolex you sicken me.
Just let me finish my pie
~ Juice
What amp are you running?
What gauge wire are you using?
What fuse holder do you gave?
What size fuse is in it?
If you have no power to the amp either your fuse blew or there is another break in your power wire that may be due to the fuse holder failure. Depending on if that break, if there us a break, is b4 the fuse connection that may be a dangerous situation
~ Juice
Your connection at the fuse holder loosened and the resistance caused it to heat up to the point of melting the plastic. Buy a fuse holder that requires lugs on both ends and crimp the lugs for the most secure possible connection.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
It melted because of resistance. Resistance causes voltage drop, and the voltage drop can and will cause a drop in performance
Pics?
Is it the type that accepts wire and you tighten a screw or does it have 2 bolts and you put ring terminals on the wire?
But if, and only of he has both the proper tools and proper terminals to crimp. Trying to do so without them is like trying to solder a terminal with a soldering iron. You can't
I'm running a hfi1500d amp with 4 gauge wire and yes it was a cheap plastic fuse holder. It was working fine wen I was riding around and then my amp just shut off at first I thought my amp just over heated and went into protect mode but that wasn't the case there was just no power going to it. And any suggestions of what kind of fuse holder is good? And I don't know how to posy a pic to the forum
BASS_BANG
It may not be visibly blown but id replace it anyways
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
  • Who's Online   0 Members, 0 Anonymous, 314 Guests (See full list)
